Tryin to put a 2nd in driveway, can you GM guys check service on VIN?
Myfirsttahoe
Hi. Going to drive a 2008 tomorrow. I'd like to check the available service records before I make an offer. I'm told the original owner had it for 5 years and worked for the dealer. Can any of you GM dealer guys look up this VIN 1GNFC13048R104055 and tell me what I'm getting in too? Much appreciated.
Gzes
the drifting 2dr
Wichita tx
The service would usually cost money so kinda doubt anybody could find out. Might be easier to get a report. Some charge as low as $30 or you can get unlimited for like a month and check multiple vin #s
soulsea
Bar
There's a couple of folks around here who have access to service records ... hopefully one of them will see this thread and help you out.
Welcome to TYF.
M
Myfirsttahoe
Thanks gzes. I've seen other posts where the service guys looked up the info on their GM databases or whatever. Also, maybe someone's got available access to Carfax where I wouldn't have to pay. Getting a little nervous about what I've been reading here about the cylinder deactivation and oil consumption. Got a 2006 5.3L with no issues.
FishinCricket
GMC Salesman
The Ozarks
Are you purchasing this vehicle from a GM dealer? The service records should be free, and if the dealer (or individual) you are purchasing it from wont give you a carfax/auto check, don't just walk away... Run!
M
Myfirsttahoe
This vehicle is being sold by an individual who has owned it for a year and purchased it from a GM dealership employee. I didn't get to drive it today because, you're not going to believe my luck, this AM my mechanic tells me that my 1999 Jeep G'Cherokee needs a reman'ed motor. Going to try for Saturday to look at the Tahoe. Thanks
doubletapdrew
Vehicle Information
VIN: 1GNFC13048R104055 Model: CC10706-2008 TAHOE 4X2 LT
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions
Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Powertrain Limited Warranty 06/30/2008 129 MI 06/30/2013 100,129 MI
Special Coverage 11273 06/30/2008 129 MI 06/30/2018 120,129 MI
Corrosion Limited Warranty 06/30/2008 129 MI 06/30/2014 100,129 MI
Emission Select Component Ltd Wty 06/30/2008 129 MI 06/30/2016 80,129 MI
Bumper to Bumper Limited Warranty 06/30/2008 129 MI 06/30/2011 36,129 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
10/20/2010 193925 ZREG----Regular Vehicle Transaction J4100 - Generator Assembly - Replace 44,075 MI
06/17/2010 190584 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 36,092 MI
06/03/2010 190213 ZREG----Regular Vehicle Transaction J6354 - Powertrain Control Module Engine Reprogramming with SPS 35,248 MI
12/02/2008 177820 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 8,325 MI
10/03/2008 176299 ZREG----Regular Vehicle Transaction T5716 - 08048 - Remove Heated Windshield Washer 60 Amp Fuse 4,690 MI
08/13/2008 174921 ZREG----Regular Vehicle Transaction E0716 - Diagnostic System Check - Tire Pressure Monitoring 2,613 MI
07/16/2007 163089 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 1 MI
06/29/2007 A04055 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
M
Myfirsttahoe
Drew. You the man. Thanks!
Anyone got a "spare" Carfax account that might show what has happened for the last 40k miles?
soulsea
Bar
I don't have any, but considering the fact that the service report is very uneventful, if I were you it'd be worth dropping the few bucks to get the Carfax.
Dahlar
Could someone please check one for me too:
1GNFK13008J100893
doubletapdrew
1GNFK13008J100893
Vehicle Information
VIN: 1GNFK13008J100893 Model: CK10706-2008 TAHOE 4WD LT
Service Contract: Yes
Order Type: 50 - FLEET
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
Vehicle has no current record of OnStar / XM Radio information.
Corrosion Limited Warranty 07/27/2007 10 MI 07/27/2013 100,010 MI
Emission Select Component Ltd Wty 07/27/2007 10 MI 07/27/2015 80,010 MI
Bumper to Bumper Limited Warranty 07/27/2007 10 MI 07/27/2010 36,010 MI
Special Coverage 11273 07/27/2007 10 MI 07/27/2017 120,010 MI
Powertrain Limited Warranty 07/27/2007 10 MI 07/27/2012 100,010 MI
Service Contract
Policy Number: 202548226 Owner: XXXXX
Description: EMRP 60/36 MG ENHANCED Deductible Amount: 200.00
Effective Date: 10/31/2008 Expiration Date: 10/31/2013
Effective Odometer: 26881 MI Expiration Odometer: 62881 MI
Daily Rental Limit: 30.00
04/15/2008 U74206 ZREG----Regular Vehicle Transaction Z2081 - ROADSIDE SERVICE (LOCKOUT) 19,000 MI
07/25/2007 A00893 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
ASG-MikeS
