Lowering My Lifted Hoe
saif najd
Wow great work
Please I have to ask from where you git the front Chevy emblem I am looking for the same or black/gray colored
98 Chevy Tahoe 2dr Sport
slipping
slipping
Rosamond, CA
Wow great work
Thank you sir, the emblem came on the truck. You can find them at pull yards or on eBay, lmctruck.com
To color it just paint or plastidip it. You can do black plastidip with the plastidip pearlizer and it will look like gunmeatal. Looks good.
saif najd
Thank you, locally I couldn't find It not even in the junk yards thats why I asked because I have to order a new one.
Thank you for the advice :)
skyhighsami
You mentioned using Blazer body mounts, is that applicable on all Tables or just 2wd?
skyhighsami
Are the body mounts any different for a 4wd than a 2wd? Do you need to replace the cups and bushings or just the bushings alone? And where did you get what you used for your swap? Did you used the graphite impregnated bushings, polyurethane bushings or stock rubber? I know it's a lot of questions but Am interested and want to make sure I get the right stuff. Because 2" of suspension plus 1" of this would be perfect.
slipping
slipping
Rosamond, CA
Do not know 2wd vs 4wd but shouldn't think so. I picked them up from a pull yard - stock cups and rubber from the blazer. Its easier if your going to just use the stock rubber. You could order poly mounts for blazer and use the Tahoe cups but you will need to trim 1/4 inch or so. I'm trying to get a few more sets but work has me swamped. The write up has the how to on cutting. You can get the whole blazer setup and replace rubber w/ poly mounts , eBay for like 90+ bucks.
Drewphil
