Bilstein HD Install
Darkie
isnt that a arnott shock?
I was wondering if you can tell by looking if it is a drop spindle
Truck was very low in front until I installed these arnott ones
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Do you have the original shock at all still? As i said before ive seen variances with aftermarket companies where the snap ring is at. If the snap ring is much higher on your shocks now that explains the lift and I can mill it down for you to lower it.
im wondering if you got the lifting ones now.
Darkie
I need to find out if I need new shocks or lowering spindle
The ones that came out looked like GM to me I just let the shop discard them this was months ago
The arnotts feel really nice just looks dumb
I think when I drive the rear comes up too meet the front
Thanks guys
Hope it's not rude to be asking questions on someone else's thread
I should have started a new one
I wish I was in cali
Blazed
Accepting Donations
Never thought of that
Thanks
Will the lowering struts by bell tech be a comparable ride to the bilstein
What do you guys use for a lowering strut
NOOOO not even close.
You should just figure out what you had on the truck before if you can.
Belltech would not satisfy you if you like anything bilstein makes.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
honestly can you be without the truck for a few days???
I can machine them down after work and send it back out to you the next day. I would just need to know how much lower you want the front. You have the struts already so might as well go with them.
Darkie
I can be without it
But I'd like to know if those spindles are drop spindles
I got a kit from you for my Tahoe I guess I can check those spindles out and compare them to the escalade
Thanks I might just ship them out to you
Do you think it would look right after machining
This is before arnott
This is after
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
what does your truck meaure from ground to fenderlip in both front and rear right now? and before you changed the struts was the front even with the rear or lower?
I cant see pics right now for some reason ill try again later.
My esky on 305 35 24
33 7/8 front
34.5 rear
thats with spindles in front and my strut mod
rear is shortened links with 5305 springs and extenders
Darkie
Rear looks like 34 3/4
Front looks like 36
The front was a little lower and looked good like that
Thanks
CT MOTORSPORTS
