ABS Light and Brake Light 01 Tahoe
576575
Los Angeles. S.F.V. & Lancaster CA
So the info can help someone else as well..., how do you know when the ABS 'doesn't work'?
I have also traced a wooden floor type creaking sound on the left rear wheel when I press the break pedal past half way. The truck stops fine btw and other than the occasional squeal that's the only crap bothering me
PwtrSS_OakCliff
Dallas, TX
Go where there is loose gravel, wet road, snowy road and slam the brakes. If your wheels lock you don't ABS or it's not working.
Antonio
ketchupaholic
Here is a photo I took of the two wires. DON'T FORGET TO DISCONNECT THE BATTERY.
[emoji298]
PwtrSS_OakCliff
Dallas, TX
It's right under the driver side underneath the truck. There is a metal rectangular piece with lines going to them. Can't miss it. You should find the ground than.
boozer
Wichita, ks
there is also a video on youtube on how to fix it yourself if you can solder. just like these wiper motors they have weak solder
dizhai
