High temp !! Help
saif najd
Hi every one,
Tahoe 98 2dr, dual core radiator + efan
Problem:
over temp yesterday up to 214F (101 C)
So I found out that the radiators was almost empty so I added tge water but still I am losing some.
So today I went to the shop and replaced the water radiator and found out that the temp valve was stuck! Replaced to this:
The old and new:
So we are done right? NO :mad:
The temp range use to be between 86C to 90C (186f to 194f)
Now no way it drop less than 194f :confused:
And I noticed something, the efans setup (by the previous owner) was
Fan 1 ---- high by radiator temp
Fan 2 ---- high by A/C cluch
Now both fans are working at the same time but the A/C compressor is off!
retorq
Kingman AZ
212 is the boiling point of water, if the radiator/cooling system was properly pressurized 212 is OK. If you can it low and there were air pockets in the head cooling jackets you probably cracked a head.
saif najd
saif najd
Nice "cracked a head" :banghead: waiting for others thanx
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you really need to find that leak. i let mine get as high as 214 before the fans kick in and it does no harm. dont suppose you have a working diagram of the efan controller do you? i can see a change that may be needed.
saif najd
saif najd
No I don't have qorking dagram and today I called the previous owner he told me that he have no idea what was fitted on the tahoe he just used it for few months I checked with a friend at the traffic department he told me there's few previous owners but the first owner info is very old and not valid any more :mad:
But looking at the half full of the glass today I learned something new because of the efans continues action the stock intake temp (and under the hood) temp was very low I did enjoyed good performance.
As you said I must rewire everything, I found this diagram I think I am going to follow it
---------- Post added at 04:10 PM ---------- Previous post was at 04:05 PM ----------
The fans must work as the following
Mode 1
Both fans working low speed continues
Mode 2
Fan 1 high speed by radiator water temp
Mode 3
Fan 2 high speed by A/C compressor cluch
SunlitComet
OBS Jedi-Do Good
yep that is the camaro setup. used in 2002 with the 0411 pcm. applies to other years as well.
saif najd
saif najd
Great thats true I remembered now they talked about the camaro
I just beed to learn how to adopt this to the subaru efans!
I think I am going to replace the efans to the yukon 2005 efans
Iam still thinking
saif najd
saif najd
What is th3 temp for the engine?
I remember it is 80c for best performance I felt the 86c was the best
And the intake remp should be less than 39c
Am I right?
SunlitComet
OBS Jedi-Do Good
just use a 195° f thermostat. for the camaro 5.7 the low speed starts at 108°C/226°F and high at 113°/235°F. i would dial it down about 5-7 degrees for the suv engines tho since we run oil and tranny coolers and sometimes more then one for a specific fluid. that way even under harsh conditions with no leaks everything does not want to get burned up to easily and leave some room for a temperature surge where the fans would already be running to stomp it down such as hard running and then sudden idle for a while in hot weather. remember we weigh more then the camaro. a 4x4 curb weight is 5500lbs for a 5/6 door unit.
---------- Post added at 09:13 AM ---------- Previous post was at 09:11 AM ----------
the intake system will make needed adjustments for the temp of the intake charge.
saif najd
saif najd
Sir, I am sure you need to visit treasure land (where iam now) I need you!
You lost me there (sorry)
By the way tomorrow we have offroad trip so I had to solve today! So after checking the main parts sellers in the area I found the identical part here it is
Thankfully it is back to normal 87 to 90
