How To Clean Window Felt
Regency
Hey guys, so I noticed some of you were hearing loud noised like "nails on the chalkboard" when rolling down/up your drivers window so here's the fix.
Now keep in mind I practice this about every so and so and I still got this much dirt.
Start with this:
Roll your window down completely:
Spray a foamy APC on a moderate toothbrush:
Scrub and try to avoid the door panel:
Mid way through:
Wiped clean and came out with two sides of this dirt
Clean just like new:
Products used:
All Clean+
Toothbrush
Cheap microfiber
2008 Yukon haha!
:grd:
Give me some feedback on how this worked for you guys.
Regency
Regency
Hope it works out for you I practice this seasonly and have never had a noise
LTLux
Most of the time its not that its dirty, its that the window track inside the door frame needs to be lubed.
Mine was real bad and the window went down slow. I took the door panel off and added some grease to the track and now just like new!
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
on mine the molding on the bottom of the lifts up. It will be ea
denalianyone
NYBlackLade08
New York
Yes this is the proper and long term fix!! My two cents
mr tahoe
Its crazy im not sure that thats the cause of my problem i went through 2 driver side glass it gets scratched from the outside!
93blkongreenpro
I'm going to have to give this a try this week. Mine sounds terrible
dizhai
