Upgrading my brakes
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Sent from my DROID4 using Tapatalk 2
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Are these the same size as my stock rotors? They seem bigger. These measure 13" across.
Freedom Motorsports
Yes, they are. The seem bigger off the truck. You should have seen the look I gave here when the rotors showed up for a buddy's Cummins dually...lol They DO seem beefier for sure. Also, keep in mind about the installation that although it won't hurt anything to do it otherwise, they are designed to last longer with the slots installed directionally "pointing" toward the front of the truck. For example, in the pic above we see the inside of the rotor hub, when looking at the slots, that would make that rotor the driver's side front.
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Ok, i'll let the mechanic know since he will be installing them.
Freedom Motorsports
One last thing, also make sure that he knows you want him to clean them well with brake cleaner. All rotors come with a "film" of metal protector on them, although the R1's don't have as much and aren't greasy like most rotors when they come, make sure he cleans them well before install.
Freedom Motorsports
With all brake installs, if the rotors aren't cleaned, it could cause a loss in braking overall until the protector is cleaned off by the pads, this could take a while. You will know right away if he hasn't when you drive off. He needs to make sure to service the calipers up to and including greasing the guide pins, make sure to use the metal hardware that came with the pads and fully flush the power steering and brake fluid. The brake fluid is a given considering the install of the lines, but the power steering fluid is just as important to take full advantage of the new hardware.
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
I could just clean these myself right? What brake fluid do i use and how do i clean them properly?
Blazed
Accepting Donations
Brake cleaner it's in a spray can.
Freedom Motorsports
Yes, cleaning the rotors is very simple. Go get a can or two of regular brake cleaner, spray the rotors well and wipe down with a clean clothe or paper towel. As for brake fluid, I recommend using DOT 4, making sure that the system is fully flushed. Not all brake fluids are the same so when you are looking at them locally, look for the brand that offers the highest wet and dry boiling point. For example, for DOT 4 minimum boiling point rating is 311*F where as brake fluids like AMSOIL offer a wet boiling point of 410*F. The best out there that I have found in this regard are AMSOIL Series 600 DOT 4 and WILWOOD. Although not cheap, they offer the best protection and fluid stability than others on the market. There are other choices that can be found locally, just remember that the best one is going to be the one with the highest wet boiling point.
I also recommend flushing the power steering fluid. But I recommend performing a full flush on both of those fluids at the very least before each winter. This way you know that they are in good shape, but in the case of brake fluid, you will also know that you aren't going to wind up with frozen brake lines that can cause problems.
Leonidas
What's Good TYF!!!!
North Carolina
Hey Chris I want to order some rotors and pads from R1, but the 2007+ doesn't show up on the menu. What gives?
Freedom Motorsports
Their catalog is still in the process of being built and your truck is one of the models they have not "gotten around to" yet. Normally, all GMT900 models use the same brake parts so looking up the parts for 2007 base model will apply to the later GMT900 models. However, I will email my rep with R1 and verify that and get back to you asap. You can also order through me directly or I can have R1Concepts send a Paypal Invoice through email for ordering. Not everything they carry is listed in the online catalog, believe me, this has been an ongoing thorn in my side.
Thank you for your questions!
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Leonida, work w/ chris directly. He is fantastic. Top notch service and communication. You wont be disappointed.
Leonidas
What's Good TYF!!!!
North Carolina
Thanks for the information and I will be getting with you soon.
I will be dealing with him directly...seems to be a real good vendor.
Freedom Motorsports
Leonidas' 2007 GMC Yukon Denali XL Brake Upgrade Quote.....
Good afternoon everyone, I wanted to put this out there for Leonidas, since no surrender is the Spartan way. Below you will find the part numbers, retail price and 15% off price of the correct parts for your truck.
Premium Series Double Cross Drilled & Diamond Slotted Rotors:
(Black Military Grade "E" Coating Corrosion Protection)
Sold In Pairs
Front Part # PDS.66057 $200.98 (15% Off Price $170.83)
Rear Part # PDS.66065 $165.98 (15% Off Price $141.08)
Eline Series Drilled & Diamond Slotted Rotors:
(Zink Corrosion Protective Coating)
Sold In Pairs
Front Part # EDS.66057 $188.98 Retail (15% Off Price $160.63)
Rear Part # EDS.66065 $155.98 Retail (15% Off Price $132.58)
Posiquiet Ceramic Pads:
Sold As Axle Set
Front Part $50.99 Part #105.10920 (15% Off Price $43.34)
Rear Part $39.99 Part #105.11940 (15% Off Price $33.99)
Example Order:
Front Premium Double Cross Drilled & Diamond Slotted Rotors $170.83
Rear Premium Double Cross Drilled & Diamond Slotted Rotors $141.08
Posiquiet Ceramic Brake Pads Front Axle Set $43.34
Posiquiet Ceramic Brake Pads Rear Axle Set $33.99
TOTAL SHIPPED PRICE (Within the Lower 48) $389.24
TOTAL SAVINGS FOR THIS PACKAGE $68.70 OFF The Full Retail Catalog Price!
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
This is cheaper than what i paid a few weeks ago! Thats a steal! I'd grab these up quick leonidas!
Leonidas
What's Good TYF!!!!
North Carolina
Man that is a great deal Chris. Thanks for the information. Phil I'm all over this deal, you can believe that.
This is exactly why I have these on my Caprice and will be getting them on my burb in a few months when it comes time for another brake job. Can't beat the prices and improved performance over stock.
JasonW4141
