Rear drop shackle help
Tricky
Illinois
My shop wants $150 so I may tackle myself. How hard was it?
Sent from E.T's Phone using Tapatalk.
blue99tahoe24
blue99tahoe24
bout that tahoe life
joliet il
Thats a better price than i got the lowest price i got was 200 but it wasnt too hard just the time because 9 times out of 10 the bottom bolts are rusted into the shackle sleeve. So they will have to be cut out with a grinder what i did was cut the factory shackles in half the top bolt will slide right out after u cut the shackle in half it will be easier to get to the bottom bolts
Foot to the floor
---------- Post added at 12:43 AM ---------- Previous post was at 12:42 AM ----------
Hey James, you have pics of shackles installed?
Ill post them up tomarrow
Foot to the floor
Tricky
Illinois
Thanks, my spring are 2 years old so bolts shouldn't be that bad.
Tricky
Illinois
Ordered some shackles from Norcal_SS, and shall be here Friday.
Tricky
Illinois
Just need some time to do. May have to be on a Sat night in garage since the month of Dec we are working a 6 day work week and Sundays are for a lil Church, lil 1800 and the rest football :)
blue99tahoe24
blue99tahoe24
joliet il
Yea i feel that been hurtin for time to let me kno if u need any help with it pretty sure u wouldnt tho and i ment to ask whats the stock height for ur limited sounds stupid but i wanna make my z71 like a limited
Sent from my PantechP9060 using Tapatalk 2
Tricky
Illinois
Not sure of height since I haven't measured it with the factory's. Being a 2wd and is lowered 2in's from the factory also. You may have to come down another 2/3 drop from how your sits now.
Sent from a Phone Booth using Tapatalk
blue99tahoe24
blue99tahoe24
joliet il
Ok coo because it sits level now 34 1/2 with the 24'on
OkcLarryD
Okc, OK
i've got a '97 2 door, 2 wd and I'm having trouble with the shackle rubbing on the fuel filler neck, the rubber part.
How have you guys gotten around that?
thanx
Tricky
Illinois
thanx
Did you get it worked out? Plan to do mine next week when I get some time off.
NORCAL SS
SUV SUSPENSION GURU
thanx
In rear you have to unscrew the factory bolt that holds the cargo hook and get a M10 65 mm x 1.5 pitch bolt. then get one of these clamps and tigten it up and will clear the shakle. anything else just hit me back
Tricky
Illinois
So his being a 2dr is different than the 4dr and needing that clamp.
Tricky
Illinois
Just finished mine, took 1 1/2 hours.
Tricky
Illinois
Thanks, funny driving to bone yard now and looking out side mirror and see the rear end lower.
slipping
Rosamond, CA
haha, yeah thats cool. i need to get some lift shackles to bring it up even instead of the cali lean. probably hit tony up next week about it. yours really looks good though. my boy just asked if it was darth vaders truck and if there are any storm troopers inside.
Tricky
Illinois
Thanks, and it's just a ex- Military, current Postal worker and his lil friends, .
Drewphil
