2001 2wd Tahoe
Big_D
SLP, MN
im new to this forum. ive been on the fullsizechevy forum for a few years. I picked up my '01 tahoe from the original owner about a month ago. its 2wd with the 5.3 with just over 140k on it. it needs some things fixed like the abs module, the front end needs a little work and the gage cluster is a little jacked up. i plan on fixing all that over the winter and start bigger mods in the spring like dropping it and some paint and body work.
so far i replaced the stock tail lights with led ones off ebay. picked up a set of 20s locally real cheap. and replaced the hood with a HD hood. the stock one had dents and rust in the middle of it from the original owners husband dropping a weed whip on it.. i have the rest of the parts for the HD front end but so far havent had the time to put it all on.
How it sits today.
i havent finish demolding yet
godoy
utah
Nice truck needs to be lowered or lifted tho
looks like mine!!
Sent from my HTC VLE_U using Tapatalk 2
B
Big_D
SLP, MN
itll be getting lowered. heres my old sliverado. i sold about a year ago to help pay bills since i was paying double the rent i am paying now to buying my house.
electro
Kitchener, ON, CAN
Cool truck man.
Did you pull the 60A ABS fuse out?
Nice hood too, get the rest done! cant want to see.
B
Big_D
SLP, MN
the original owner had the shop she took it to pull it out before i bought it because it was killing the battery. almost a foot of snow came today which stopped me from working on it anymore this weekend.
this was this morning and its been snowing all day and still is
godoy
utah
I like your Silverado its sick!!!
You going to fix the abs yourself ?
I have the same problem
electro
Kitchener, ON, CAN
Far as I know you just replace the Electro-Hydraulic Control Unit... Which is mounted to the left frame rail underneath the drivers seat.
Actually though your best bet is to get it scanned with a tech 2 or I just went to the dealer, I dont know really know much about scanners. Anyways, get the codes from the scanner and you will know where you stand. The EHCU currently is not setting a Check Engine light for me but is the only code the dealers scanner will produce. That being said, Im not going to replace my Wheel Speed Sensors which are located inside the hub/bearing assembly at each front wheel. I am going to replace the EHCU assembly with a used one if I can find it. ABS is nice to have for sure - especially with that much know!!
B
Big_D
SLP, MN
i found a few places online that rebuilds them alot cheaper than buying a different one that will fail in time
edgaranah1
Corona California
Wow that's alot of snow.
Sent from my iPhone 4g using Tapatalk
B
Big_D
SLP, MN
finished taking off the molding and emblems tonight. the eraser wheel worked like a million bucks!
i thought i would be satisfied with taking just the roof rack cross bars off but i wasnt so the whole thing came off. still have to deal with the strips on the roof but i think those will wait til spring.
B
Big_D
SLP, MN
felt motivated today to load up my parts and head out to my buddies shop
HD swap done in just under 2 hours. once we go rolling i forgot to take more pictures. you have to trim a little bit on the side bumper brackets for a good fit otherwise its cut the mounts off and drop them down.
stock location of the bracket
cut off in a snap with the plasma cutter
Z71 lower valance with pro burner fog lights.
shaky after dark shot before the snow flies tonight
B
Big_D
SLP, MN
going to pick up some goodies for the truck tomorrow and checking around to see how much it'll cost to get my hood painted.
---------- Post added at 10:22 PM ---------- Previous post was at 09:39 PM ----------
oh and i have put my truck to the test draggin a car trailer with vehicles on it this year
Drewphil
