NathanJax's 2007 Yukon Build
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
Nathan, i have a 12589 sitting in my garage i'll sell ya. It was used for about 6-8 months i think? Name your price bud and i'll hook you up if you want it.
Sent from my DROID4 using Tapatalk 2
PMed
Goodinblack
I Like Tacos
Dirty South
@ Felix.
That thing was installed so clean it looks like it was soldered in.
The biggest one Magnaflow makes is a 5x8x24 is it not? Wouldn't that one be the quietest?
It is 2 inches longer.
Also, can someone explain this setup.............http://www.youtube.com/watch?v=jjgdTNymxdk
They are using 2 smaller mufflers as resonators?
So this is quieter than ONE 12589? Correct?
Thanks.
NORCAL SS
SUV SUSPENSION GURU
no magnaflow makes the 5x11x22 which is the quietest. You will not need anything else with that one. Listen to my escalade video even with 3.5 pipe and resonator cut off thing still is not loud just a good clean tone.
Goodinblack
I Like Tacos
Dirty South
@ Tony...........
So to clarify a 5x11x22 is QUIETER than a 5x8x24, even though it latter is 2 inches longer.
The reason I ask again is because Magnaflow told me the opposite of this, and since many companies have trained monkeys answering the phone........... I asked here again.
Also, looking at your video Tony...... is how I came across the other Escalade video. :hands:
NORCAL SS
SUV SUSPENSION GURU
Overall surface area lxwxh
5x11x22 is a nice chunk bigger then 5x8x24.
I have a 6.2 which is louder then 5.3
6.2 have 3.5 cat back 5.3 has 3 inch
I'm not running resonator in mine
Also look at the design of the stock resonator I out pics up it doesn't do much.
felixgun
Lafayette, LA
@ Felix.
Not sure which one is the biggest but I know the one I got is definitely one of the bigger ones. Also yes since I got the same configuration as the stock muffler it made for a really clean install and fit. Highly recommend this one to all you yukon/tahoe guys.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
So since my intake has been on, my mpg has gone up by 1.1.
I go the exact same way to/from work everyday and was averaging 15.3 before and now I'm getting 16.4
Still haven't had a chance to get it tuned yet...
MACHO
Seattle, WA
Nice! Interested to see of the numbers drop like mine did after a couple weeks.
jdpber
GOLD MEMBER
The America
I drive like old man to and from work. No need to be romping on the gas.milk every last mile out each gallon
MACHO
Seattle, WA
I hear ya. I drive the same way...most of the time. Mine went dipped 1 mpg after it went up 2, under the same driving conditions. I believe the ECM is learning & compensating for the intake... More air means its compensating with more fuel...that is only a theory. I'm no expert on this subject. I know merely enough to be dangerous. :)
We discussed this in this thread: http://www.tahoeyukonforum.com/forum/showthread.php?t=44858
Durobans
