truck is leaking AGAIN!!!!
Donnie Yukonie
Yates Caretaker
:emotions122: going for a drive to troubleshoot be back in a little not coming from rad or water pump be back shortly
Donnie Yukonie
Donnie Yukonie
Yates Caretaker
yea its coolant found the said "leak" but maybe im just uneducated , its coming from passenger side next to the exhaust manifolds there is two lines that run into my firewall i got pics coming soon im uploading them now, the said leak looks like its supposed to leak
---------- Post added at 07:03 PM ---------- Previous post was at 06:43 PM ----------
ok so i got some pics this one its the piece that two hoses go in and two come out, it looks like it has like a drainage port at the bottom. maybe im just paranoid and never seen this b4 but im pretty auto savy but have to admit i have no utter clue what this even does or whats its called. it does look like a simple fix however
you can even see where its leaking on the frame above
this one is just for reference on location
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Hard to say if it the water valve or split hose. Looks to be at the very top tho. Just get a new valve and some extra hose and it will be fine.
---------- Post added at 07:36 PM ---------- Previous post was at 07:33 PM ----------
That top hose does look really deteriorated in the pic.
Donnie Yukonie
Donnie Yukonie
Yates Caretaker
part number ? and i might just go ahead and replace all the lines
Duck tape?
this guy
Gzes
the drifting 2dr
Wichita tx
If u cant duck it **** it. Lol jk but yea its probably just a hose so get it n fix it
Donnie Yukonie
Donnie Yukonie
Yates Caretaker
yea i think im going to try and fix it tom maybe sun do you have a good part number? or brand
Tbruz
Windham NH
Its the heater mixer valve.
Delco P/N 12380318 about $35 from the dealership.
Tbruz
it's unlikely that the valve is actually the problem, most likely is the hoses and/or clamps but while you're in there with an empty cooling system, might as well change all that out anyways.
TORONTO 95 GT
Mine was the valve and not the hoses. Like said before, change it all and be done with it. That is what I did but even after that I chased leaks, quick connects and then the intake started weeping but not into combustion chambers or oil, just leaking to external. I have not pulled the intake yet as I will just pull the motor and either crate it or rebuild it. 95 TBI with 200K miles on it will do well holding something in the middle of the lake.
Gzes
the drifting 2dr
Wichita tx
The valve on my dads truck did the same but it broke so yea they can go bad. But hurry up n fix it don before it goes boom
Candielaine
