Who has gone up to 20's?
jem556
KY
In my experience, I noticed a negative effect to steering and handling but not really a negative effect from the reduction in tire sidewall...if that makes sense. My steering response feels more "go-cart" like than before...with the heavier wheels and wider tires I feel more slack and seem to do more correction to keep the vehicle in my lane than before. The more uneven the road surface, the more noticeable it is. I have had my entire front suspension inspected for worn components but everything checks out ok so short of ugrading from the OE components, I don't think there is much I can do to improve this. Having said all that, I wouldn't go back to 16's or 17's because I get a lot of pleasure out of driving my truck with with the improved appearance of 20's.
Alex33
I had them on the truck from about 4 months after I got it and I'm a fan. I couldn't imagine driving with OE 16s. My ride is pretty firm but that's more because my truck is lowered so much.
CEN2MENTAL95
Banned
Expensive Long Island, NY
the 20's increase the looks of an already beautiful truck IMO and seem to me to be the perfect size between looks/performance and comfort
with that said, the ride is def better with stockers
JochenWoern
Sacramento, CA
+1. When I purchased, I had OEM 16" inch rims but a total OFF Brand All Terrain Tire on it. So when I switched to the 20" inch Denali wheels with the Bridgestone Duelers, the improvement in ride quality was enormeous and the truck was not as loud at Highway Speeds. I will alwas run with 20's, as it is for me the perfect size for looks as well as all around use.
You will never see me with 24's or 26's with rubber bands as tires around them, as I like to go off the pavement and that does not work well with bigger rims and less rubber.
LuSe4
Bleen Member
Michigan
I prefer the ride with the 20's over the stock 16's until the road gets really bad. When it gets really bad, you can definitely feel a difference. Can't tell you exactly, but you can almost feel the extra weight at each corner. Don't get me wrong, it isn't terrible, and definitely worth it for the looks and enhanced handling over the stockers.
Driving down the highway (which is where mine is 90% of the time) it feels almost indistinguishable from stock.
x2. Exactly my experience from when I moved up from 17's to 20's
OHSIXX
Milwaukee
Mine came with 20's and the ride is great-no complaints.... You will be just fine ;)
Yukon&Tahoe
You'll love them.... Good choice! :headbang:
As for ride quality.... We have both a 2000 Tahoe on either 16's or 17's (Winter / Summer Setups) and a 2007 Yukon Denali on 20's. I love the ride of the Denali on 20's, maybe it's the air ride, but it's as smooth as glass in my opinion (keep in mind I've only driven pickups from the age of 15). To me the 2000 is smoother than my 2004 Crew cab pickup, but not smoother than the Denali.
Not sure if that's a fare comparison, but It's what I can go by....
T
I am pairing them up with some Hancooks...I have been REALLY impressed with everything I have put them on so far...hopefully it holds true here too.
LuSe4
Bleen Member
Michigan
I second Jochen. We love pics here.
Those wheels should look great on there.
mmeachem
Yup I got 20" to and have no problem and love the wider stance with the 285 series tire
post pics when mounted
aldrichg9
Thats weird.
I have had great luck with the RSA's on my wifes charger.
60k miles on them needing replaced until it got wrecked today...
I am not a korean tire fan but I can tell you my Goodyear Eagle RSA's are nothing to write home about and they were quite expensive!
OHSIXX
Milwaukee
I can't wait for my Goodyears to wear out........they are the noisiest tire I have ever had-anytime I am on asphalt and turning-it sounds like I'm doing it at about 40MPH ;)
My GY's do the same thing when turning. My next tires will either be michelins or 420's
T
before:
---------- Post added at 09:53 AM ---------- Previous post was at 09:51 AM ----------
My dad put Michelins on his 02 Suburban...they wore out FAST.
veteran111
