pillar gauge pod
the big blue bus
richmond, va
so my trans overheated and is all messd up and im about to rebuild it and got to thinking of adding a trans temp gauge and a water temp gauge and maybe another? any ideas on another one to add. if not i may just get the full 2 pillar one. thought about adding a diff temp gauge but no idea if it was realy neccesary
_Dylan_
STAY FROSTY
Trans temp would be my first choice, then maybe an oil temp or vacuum. Maybe an air pressure guage for an on board air tank/compressor.
the big blue bus
the big blue bus
richmond, va
thought about air pressure actually in the top spot. goijg to do trans temp but unsure if i should do another. may get the body shop at work to blend it in to the stock pillar cover not sure yet. need to get trans fixed and then think about adding gauges
stereodesigner
Boost gauge lol.....Rig up a way when you increase rpm the boost gauge builds up lol
Sent from my DROID X2 using Tapatalk 2
the big blue bus
the big blue bus
richmond, va
lol ^
where would i put the sensor for oil temp? so ive got trans temp, oil temp not sure if i should do another. would diff temp be point less and better off if i do a air pressure since i want to do oba and a tank where spare was. anyone have pics of theres? cant find many pics online
ezdaar
Chat Troll
Redneck central, Aka Houston
simple and non invasive way to add a oil "whatever" sensor is to get one of the remote oil cooler plate adapters that screws on in between your block and oil filter.
Simply get the correct sensor and screw it in aswell as pluging the return port on the plate adapter.
Triple gauge pillar, run a trans temp, oil temp and a vacuum gauge..
maintaining a high Vacuum is a REALLY good way of improving your mpg.
foreverfalcon40
Why would you get a oil temp gauge on a N/A unmodified set-up?
What about tranny temp and a nice little light show like an A/F gauge or digital volts gauge?
I love autometer gauges, but my buddy has Glow Shift and has a tranny temp with a digital volts gauge built into it. They have different set-ups and are economically priced
http://www.glowshiftdirect.com/
SunlitComet
OBS Jedi-Do Good
unknown at this time.
To see active temp of oil cooler effectiveness it should always be a little different then coolant but that coupled with coolant pressure gauge could help indicate a leak between the two giving time to prevent contamination.
the big blue bus
the big blue bus
richmond, va
still need to figure what im going to do. got my trans out fonnaly so trying to order some parts now. i know i was trans temp but i dont really like how the single pod looks would atleast like the full 2 but not sure of another gauge to use
foreverfalcon40
A/f nice little light show. While you at it...get a deeper trans pan! Want you tranny as cool as possible!
99TanHoe
Louisiana
Another gauge you could add if you do alot of towing is rearend temp. The MagHytec Diff cover that I have has a plugged threaded hole where a temp sensor can be added.
johnsonwillie199
