Engine setting for years, what's the best way to prepare for start up?
HDRock1
HDRock1
Flint,Mi
Well ! I got it fired up, but only by squirting gas in the throttle body, because I have no fuel pressure with the gauge hooked up, can't hear the pump running, relay is clicking fine, I beat on the gas tank . Still no go.
TORONTO 95 GT
Well at least you know where to look. Hope it all works out and you get her up and running on the road.
HDRock1
HDRock1
Flint,Mi
Got the new fuel pump harness wired up,and tested correct, took all day to clean the inside of the tank, there was a lot of crap in there.
When I finished up I went in the wood shop and got some tack rags, to get the last of it out
The old fuel pump didn't have a chance in that environment.
HDRock1
HDRock1
Flint,Mi
HDRock1
HDRock1
Flint,Mi
That is probably the brake line that crosses from the abs module to the right wheel brake caliber. It is brake fluid right?
Ya it's brake fluid
Now I will have to find out how these brakes have to be bled, once I repair the line
Chuckchill
