iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
The other day I noticed that the second cigarette lighter port in a Sierra was actually the USB port. Has anyone tried converting one of the front two lighter slots to the USB port instead?
20944422
20888040 USB Port Cover
20944422 USB Port
It looks like you can use just the cover part and put in one of these http://www.amazon.com/SANOXY-USB-Fe...&sr=8-2&keywords=female+to+female+usb+adapter. I have that piece from when I was going to try this earlier so I may try it and see if it works.
Nathan use the piece I linked to at amazon, skip the factory electronics, use factory plug.
i think yates is on the correct track...
I don't see how the rectangular part goes in the dash. It says it goes in the center console.
If the $30 factory adapter has the female USB inside the dash (like the pic you posted) I'd rather it look factory...
This is the rectangular piece I meant.
you remove one of your 500 cig lighters GM gives you and this new housing pops in.. most likely has compression clips on the back side. then use the linked connector that yates shared.. that pope into the round plastic area int he rectangle slot. then you have a couple foot USB extension (radio shack or MONOPRICE.com) adn that goes to your head unit..
i wonder how this will look in an NBS ?? humm
So your saying just make a piece instead of buying the $30 piece
and your saying buy the factroy piece, but pop out the factory electronics and just insert the amzon piece yates posted to the factory black plate
