Anyone have a prob with there auto start
bosworth496
Mira Loma Ca
I go to start my 07 Tahoe from the key pad and the back hatch opens tried to reprogram it a bunch of times still nothing wondering if anyone else has had this prob
Ben
PCB, FL
Never had that problem but I have had mine not start a few times.
yates ™
Resident Apple hater
Iowa
Maybe remote got wet or moisture in it and it shorted? I would say it is in your remote unless it does it with both remotes.
pmexpert
Moscow, Russia
So maybe something is wrong with radiomodule in the car.
You can try to reconnect the module or overwrite it using SPS. But you will need official GM service for that.
Sent from my iPad using Tapatalk HD
yates ™
Iowa
Whatever controls the remote start feature is faulty.
pmexpert
Moscow, Russia
As I understood it only opens a hatch. So it doesn't open the doors as well
bosworth496
bosworth496
Mira Loma Ca
It unlocks and locks the doors everything works but when you hit the key pad to start it it just bypass to the hatch
GM Customer Service
Michigan
The fob may just need to be reprogrammed or their may be an interior component damaged. Stop by your local dealer, they will be able to assist you further.
Louis
GM Customer Service
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
check your settings in the dic? Try restoring to factory defaults.
maxls00
brooklyn NY
i also have a problem with auto start on my 07 denali, when i hit the auto start the lights blink that the signal went trough but it doesn't start
fire730
Louisiana
Is your check engine light on?
And to the original poster - has it been acting up the whole time or did it just start doing it?
JochenWoern
Sacramento, CA
+1 - If the check engine light is on, this is exactly what happens but the truck will NOT start!
---------- Post added at 11:04 PM ---------- Previous post was at 11:04 PM ----------
Tried that they don't get why it's doing it
Go figure!!!!!!!!!!!!!
maxls00
brooklyn NY
yes my check engine light is on thats what i figured it was!! thanx
this damn p4055 code won't go away
SmallXL
I've this issue on and off since day 1. GM has trouble diagnosing it b/c it is intermittent. Issue has never been resolved.
FMBL
I bought my 07 Yukon in November. The remote start has not worked since I have had it. The spare fob did not work either. I just got back from the stealership. They said the spare fob was no good. So I bought a new one and had them reprogram both. They could not fix the issue with the rear hatch opening what they tries to do the remote start. They said they cleared the pc and let it relearn the program and still had the same issue. Now they say that they think it's a module on the starter that could be anywhere from $80-$200 and about 2 hrs labor. But they would have to run diagnostics first.
Has anybody figured out their issue yet?
dizhai
