Hey Guys, I bought the Baer Eradispeed rotor kit last year but I wanna upgrade the calipers now, the stock ones only grab about 3/4's of the rotor and I don't like the way they sit on the rotors. 15" on the front 14" on the back, any advice?
Is that what you are going to do Simran? I am needing a brake upgrade but don't think I really want to drop $4500+ on a big brake kit (though they are badass). This looks more like the amount I am willing to spend and I am just wondering how they perform compared to stock?I have the same kit, and emailed baer a while back asking if i can upgrade the calipers and they said i can add the alumasport calipers. Heres a copy of the email and part numbers:
Hello,
You can upgrade our EradiSpeed to the AlumaSport caliper (making it an AlumaSport brake system).
Front 4301064 Caliper assemblies with pads both front calipers $895.00
Rear 4302047 Caliper assemblies with pads both rear calipers $895.00
Thx!
Rick
Unfortunately you can't do anything with those rotors. You cannot upgrade the Calipers to anything else. You want be able to use the Aluma sports either because of the mounting points on the caliper. The only thing you MAY be able to do is get Z06 Calipers but then you will need to find someone to measure and make the brackets for them to fit.
Hello,
Thx!
Rick
Thanks for the info, did you order them through Baer? Their website doesn't seem to work to well. Do you still need to use the adaptor brackets to make these new ones fit? Any pics? Man, I would love to buy the Wilwood kit but dropping 5G's on a brake system is a little out of my budget.
Ok, I must have been really wrong about the aluma calipers. Sorry about that. I was just pretty sure that the mounting points of the stock calipers and the aluma sports were different. I will have to dig out my stock ones and compair to the the aluma ones I have now. Sometime this summer/srping I need replace the front rotors because one side I have worn off the slots completely. So I might do the 15" rotors then if I can with the Aluma kit then I will evently have my brother make me a mounting brackets for the Z06 calipers.
