Spark Plug Question
Max
Mile High
Denver
You can gap em to .035, won't hurt anything. More people run a tight gap for nitrous but you'll want to swap to a lower heat range if you're going to spray. I've done plugs twice on my truck, with an angle socket and a few various extensions it should only take 10minutes or so. I'll be swapping to tr6s gapped to .035 by next month if all goes well :evillol:
Max
Mile High
Denver
Nope too broke for that cuz I want to do head/cam/tvs/stall. 100 shot should tide me over for a bit, probably do a fuel pump and some bigger injectors if my duty cycle gets high but the longtubes actually dropped them.
Robert.K
San Diego, Ca
speaking of wires, any suggestions? Might need to start another thread for this one, cause Im totally lost when it comes to this subject.
Max
Mile High
Denver
Wires aren't very important, the stockers will suffice if you never plan on upgrading to aftermarket headers. MSD 8.5mm are working well for me. Buddy does some machining for a nitrous store so I'm hooking a plate system for cheap.
tybardy
everyone needs a Hoe
Gilbert Arizona
damn, i need buddies like you gots!
yea i wasnt gonna do 8.5mm wires but i need to replace mine and i plan to get some LT's in the coming months, so nows a good time.
I'm trying to stack my chips so I can get the LT's, Cam, and e-fans all done at the same time, then have the hoe re-tuned. Was likeing that ZEX setup for under $800 though to go along with it
tybardy
Gilbert Arizona
hey... for some reason i cant find the TR55's anymore... are the TR5's the same plugg? its part number 2238
YNOT
i just asked o'reily's for there standard ngk plug that came gapped at .040
Max
Mile High
Denver
Yeah same stuff just has .040 gap. Check em before install and don't forget the anti-seize.
jpurdie
