I recently replaced both CV Axles on my 2011 Tahoe 4WD. I did remove the struts on both sides to gain clearance. The struts are fine so I re-installed the original.
Question - Do I need to do an alignment after this work? Anyone care to share their experience/thoughts?
My understanding is to perform wheel alignment one adjusts the eccentric cam bolts on the upper control arm for caster/camber, and the outer tie rods for toe. Since I didn't change those, and used the original struts, I am hoping my alignment did not change. I don't want to waste 150 bucks getting it aligned but I also don't want to end up with premature tire wear. I took it to a shop for a quote before doing it myself and they recommended an alignment, but it may just be a CYA move on their part?
Thanks!
