- Joined
- Jun 9, 2009
- Posts
- 8,744
- Reaction score
- 605
Guys i cut off the resonator on my escalade and left it turned down and replaced the main muffler with a magnaflow 12909. The stock exhaust is 3.5 inches from cat back so by far best way to spend your money.
muffler you can see thru
installed
NOTE--- you will need to get about 2 inches of straight 3.5 inch pipe. You can cut the portion before or after the resonator and weld that on the pipe coming into the muffler so everything will fit in.
And here goes the stock muffler you can't even see light thru it from other side
Now on these mufflers takes about 1 month to break in fully. So far the truck has got louder and no real noise inside. Sounds great!!!
Also I did notice a gain on hp when we stomped on the gas. My main concern also is that all the aftermarket cat back exhausts for these trucks are 3 inches and like 600-1000 dollars and stepping from 3.5 to 3 inch is not the best at all.
Save your money and make more power by doing this set up.
http://www.youtube.com/watch?v=I_E5417xFVo
installed
