Interior LED How to
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:welcome: If the bulb are polarized turn them 180 degrees to reverse the polarity but first make sure your dimmer it turned up on high brightest.
the big blue bus
richmond, va
just replaced a few of mine wiht the basic 1 led from sbl. looks good to me. need to replace the dome lights now. and fix the ac controls too. may upgrade dash to brighter blue. how do you replace the door controls with leds? cant find a right up on it. want to do that soon. want them brighter and blue. also mine being a 95 the ac control lights are wired in. can i just unsolder them and replace them?
Donnie Yukonie
Yates Caretaker
yea i found them orderd 6 of them i was looking at the wrong one but wouldntthe 360 degree ones put off more light by spreading it out more? justa thought
95'Hoe
So, is the 95 2 door Tahoe one that has them soldered in or is it simply pull the old one and pop the new one in? Side note on this, since the guage cluster is already pulled - how easy is it to put a new guage face on?
skintahoe
My cluster bulbs are all soldered in so where do you get sockets that allow for the leds to just be plugged in? Or are you somehow desoldering the sockets? Went to napa all they had was 194 bulbs already soldered in the sockets as well....
95yukonslt
here http://www.superbrightleds.com/cgi-...on=DispPage&Page2Disp=/specs/T10_sockets.html i had to order these, my stock ones were soldered in place too
---------- Post added at 01:51 PM ---------- Previous post was at 01:49 PM ----------
theres two different types
these 42mm http://www.amazon.com/gp/product/B005DS9IFM/ref=oh_o00_s00_i00_details
and these http://www.superbrightleds.com/cgi-...ion=DispPage&Page2Disp=/specs/RL4410-xHP9.htm
95yukonslt
I am also wondering what the white ones would look like in the dash. I dig the blue... it matches the Alpine but with a Pewter Yukon I am not seeing that blue matches too well. So has anyone just done white? I am thinking it might be obnoxiously bright.
they look good
95yukonslt
I too want to replace the HVAC, headlight switch, and door panel switches, but you have to replace the whole socket...anybody know the number of the neowedge for these bulbs, im at school right now and away form my yukon so i would like to order them so when i get back i can replace them. BTW its a 95 yukon slt 4 door 4x4 if that makes a difference
juggjiggler69
I changed all mine to red in the hvac,headlight,front doors so far waiting on the 2mm bulbs to get here will post pics when done
Sent from my Galaxy Nexus using Xparent Blue Tapatalk
juggjiggler69
Hey val they will work u mite have to trim the white plastic a little on the sides but thats it,that is wat i had to do good luck
_Dylan_
STAY FROSTY
i was looking on eBay and i found these leds http://www.ebay.com/itm/220951855636?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 but it says there not compatible with mt 1996 tahoe im not after them for the dash just map lights and courtesy lights they say there 194's any info would help thanks
Those will fit the door/under dash courtesy lights. I'm not sure about the map lights I've haven't gotten around to swapping them.
Those will fit the instrument cluster also. I bought blue ones and they don't have hot spots.
This is the ones that I bought if you don't want to wait 2-3 weeks to get them from china.
http://www.amazon.com/gp/product/B005ETCIO8/ref=oh_o04_s00_i00_details
They won't fit the door lights, you will have to widen the holes with a drill to fit the bulb.
valic007
thanks for the info guys i went ahead and ordered them and now im gonna do some searching on how to put led's in my 4wd switch the bulb that are in there are burnt out
juggjiggler69
Hey valic i am sure you will have to solder the one in the 4x4 switch i am doing that this week when they get here
juggjiggler69
And dylan if you mount that monitor where your radio is where are you putting the radio,i have been sceaming on this idea for awhile myself just not sure how i want to set it up
brice715
