HID retrofit w/ Bi-Xenon Projector on 06 Suburban
wowthatnice
The first thing that you think of when you think "projectors" is the cutoff, right? That's why I'm doing this.
Installing a set of eBay (or any other brand) HID bulbs into your halogen housing will look good (which I did years ago.) but it presents a problem. They put light on the road, sure, but not only is the light output pretty janky and inconsistent on the road but the glare is ridiculous to other drivers. So now I'm retrofitting the projector to "cut off" the light before it reaches other people eyes, they don't see any glare at all!
This is all the parts that I used to make it work:
  1. Morimoto 3five ballast (my old setup)
  2. Morimoto 3five H1 4300K bulb (my old 4300K 9006 bulb don't fit on this projector) - $40
  3. Morimoto Mini H1 Projector - $120
  4. Clear aftermarket headlight housing (my old setup)
  5. Some epoxy and silicon - $20
Completed in 2 hours which cost me $180 not including tools and parts that I already have.
I removed everything that I can prior put it on oven to bake at 300 degrees for 15 minutes.
After baked, I use flatblade screwdriver pry the front lens apart. Some people have to reheat it again but since I do it w/15 minutes @300 so it's very easy to come out like this at once.
This is the Morimoto Mini H1 projector with clear lens that will go right inside the headlight (without trimming and cutting)
I put everything together and it look like this
My all times favor tool to trim and make hole bigger to fit the projector's adapter plate (h7) fit in.
Now it fit right in with plenty of room for the lock ring and bulb holder in place. Just to make sure I use some epoxy to glue it (of course after aligned to find good beam pattern)
I then reheat the oven with 300 and bake it for another 7 minutes so that I can reuse the old glue. I use some clamps around the edges to hold the housing together while it cools down and the glue hardens
Once it all cools down, I remove the clamps and put on some silicon around it to make sure no moisture or fog on it.
Let it dry for 5-6 hours and it's time to put it on
And front view with light on
Both of them on
Next step is doing the fog. Still thinking between the blazers or matchbox mini projector...
soulsea
Bar
Awesome work Rau. :waytogo:
Pics of the cutoff pretty please? :)
W
wowthatnice
Will take some shots of the cutoff later on tonight.
---------- Post added at 07:29 PM ---------- Previous post was at 07:17 PM ----------
Very nice!! What was your process in aligning them?
I just hand-tighten it at first, and installed it back to the car without the lens covers and park the car 25 feet away from the blank wall. I rotation the projectors till I get the good pattern and cutoff then mark with tape and pencil on the projector and housing so when I take it out if it move I know where it at. Remove it off the car, tighten as hard as I can. Just to make sure, I put some extra epoxy around the nuts to avoid any rotation and vibration while driving.
rippinitup
NY.
nice job bro looks good.im trying to decide on projectors right now, looking forward on output pics with those projectors.
DenaliAK
Colder than you
Alaska
Looks good. Pretty easy retro, too. Also looking forward to output pics.
:popcorn:
soulsea
Bar
I agree ... I'm thinking of summoning up the courage to do a fog light retro.
waxworkz
damn that looks nice. did you order the stuff from theretrofitsource? i've been looking for the cheapest place to buy those projectors. i now have 2 cars i need to do this to and would rather just buy the projectors and hid bulbs at the same time
W
wowthatnice
here is the quick snapshot with my poor phone quality camera, will try again with better camera when I have a chance.
Park 20+ feet away from the Stop sign
---------- Post added at 02:08 AM ---------- Previous post was at 02:01 AM ----------
Very awesome can you make me some ?
Sure if you live near by. Just bring over the parts need it for your retrofit along with some beers :)
W
wowthatnice
Thanks...
It's was black friday deals so I got a few pairs from The Retrofit Source. I'm waiting from Matt (retrofit source's owner) get back with me on the Matchbox Mini (smaller version of Morimoto Mini) so I can put it on my fog.
I have the Xentec (ebay), DDM, Morimoto and Knight Xenon bulbs and ballast. And so far the output of Knight Xenon a bit better, maybe it's was make by German. But with the new setup I'm going with Morimoto kit (bulb and ballast) since it's smaller in size to work with.
I suggest you to put your invest on Morimoto for longer run and quality and it's much cheaper than Matsushita and Denso (which I always wanted to have).
soulsea
Bar
Rau, even if you aren't ready to buy the full kit just make sure you buy the micro gatlings asap from trs. Andrew told me a couple of weeks ago that there's very few left and as far as I know they're the only shrouds that'll work with the matchbox projector.
Light output looks good bud. :waytogo:
Buford bubba
