looking for a 3/5 kit
Ryan1126
looking for a 3/5 kit for my 2010 tahoe ls 2wd. I want to keep as close to the stock ride as possible!! also i would like for it to all be bolt on so i can easily go back to stock height. as of right now its on 26*9.5 wheels on 305's. do you think i will get a lot of rub?
NORCAL SS
SUV SUSPENSION GURU
here you go
http://www.tbssowners.com/store/index.php?act=viewProd&productId=140
all bolts in but in rear you will have to do the free travel mod.
if your on 305 30 26 honestly i would do this kit
http://www.tbssowners.com/store/index.php?act=viewProd&productId=87
Ryan1126
Ryan1126
NORCAL SS
SUV SUSPENSION GURU
the front spindles wiht the rear 3-4 inch adjustable kit you wont have issues honestly. Belltechs by far are one of the best riding 3-4 inch coils out here which many will agree with.
in rear you will need to do the free travel mod at the 4 inch level also on 305 30 26 when you do cut the bumpstops off i would get the stepped rear bumpstops which you can cut down to the right size. That way you can set the bumpstop to have most travel and not let the rear end hit the fenderlip if your offset is wrong.
Ryan1126
Ryan1126
so the free travel mod is cutting the stock bump stops off and replacing them?
NORCAL SS
SUV SUSPENSION GURU
here you go after pic
and before
CKendrick
