Stacked leveling kits
07Z71hoe
I recently saw an 07 Tahoe for sale and it had 35" nitto terra grapplers on it so I texted him an asked him how he fit 35's without suspension lift an he said he just stacked two leveling kits. Anyone else heard of this? My 285's are getting warn down so in the next few months I wanna get at least 305s but if stacking kits is possible then I'll do it.
protonvx
You can, but the angles of all the suspension components will be extreme and more than likely cause damage down the road. Go ahead and try if you like, but my guess is you will be needing new balljoints and cv shafts rather soon.
Not to sound like an ass, but do a google search for nnbs stacked leveling kits and I am sure you will find some threads on the truck forums explaining why not to do this in more detail.
New Orleans, LA
You dont need to stack leveling kits to run 305's. Im running 305's with a CCM kit no problem. Dont take the risk by stacking the leveling kits because its highly unsafe
Zed 71
Pacific NW
Yep, do not stack leveling kits. As mentioned above, this would be beyond the dynamic range of the suspension and it is not as strong.
07Z71hoe
07Z71hoe
Ya I guess I'll do 305s. Really want to do 35s though! Ha and not willing to pay all that money for a 4 or 6in lift
protonvx
If you are willing to do some trimming you can run 35s with out spending $1500+. Run a 2.5" lift kit in the front and do a 2" body lift. If you are running +32mm offset and do some trimming, 35s are possible. I am running 34s with just 2.5" front lift and 1" rear lift with minimal rubbing on +32mm offset wheels. I drive 98% of the time on the street, so I do not need much clearance for articulation. If I were to decide to spend more time offroad, I would need another 3-4" of lift.
07Z71hoe
07Z71hoe
Could u post a pic of ur ride? And I have 2.5 an 1 in back leveling kit already. Nobody makes a body lift for nnbs Tahoe though
Autbond
I have heard of people using a 4 inch lift that was designed for a silverado, I believe, to fit 35s. But your gas mileage will suffer greatly, 305s are big enough! They are basically 34.5".
Zed 71
Pacific NW
^ Do you take it offroad? Body lifts are simple if you have a hydraulic lift. Also need to make sure brake lines and such have enough length.
protonvx
My Yukon:
protonvx
Instructions for the Zone BL:
http://zoneoffroad.com/Instructions/C9251.pdf
Should not be hard to install, just time consuming.
---------- Post added at 02:03 PM ---------- Previous post was at 02:00 PM ----------
Zed, if you are asking me, I do not go offroad much, I have plenty of clearance for straight line trails, I would need more for articulation when turning.
New Orleans, LA
I have been looking into getting a body lift because I wouldnt mind clearing some 35's. I was hoping someone has done it so we could all see what it looks like. I wouldnt mind **** this if it looks good.
I wondering how it works for the front and rear bumper along with the trailer hitch? Can you still tow with a body Lift?
O2bwln
Please don't stack leveling kits. The fact that you're introducing ridiculous amounts of shear forces to these locations every time you turn, not to mention the stress that is being channeled to your mounting points will end in a very ugly mess.
Save your money, get a legitimate lift and don't be that guy that causes lives to be endangered because you wanted to sit higher.
These vehicles are great to modify but do it right, stacking leveling kits is a very dangerous way to gain height.
O2bwln
protonvx
I think that both Zone and PA say you can't tow after you modify the rear bumper. But I don't see why not. From the pics in the instructions it appears that the rear bumper would be stronger after the Body Lift. I know that if I end up doing it this winter, I am going to use the Zone lift and will put a couple bolts in and get everything lined up, then take it back off and weld the new brackets to the bumper along with a few grade 8 bolts. When I am done with it, it will be stronger that it was from GM. I know if you search you can find a couple guys that have installed the body lifts on other forums.
Zed 71
Pacific NW
I was asking the OP. Good point about the trailer hitch. I forgot that needs to be addressed. Also are the side steps mounted on the frame? If so there would be a noticable gap depending on body lift size.
protonvx
I am pretty sure that the running boards attach to the body. The pics I have seen of the nnbs SUVs you can not see the frame hanging down below the body.
ProTour 67
I have the same 2.5/2" am trying to figure out if the rear spacer will work with the auto ride.
Any input
Brock
Senior Member
NC
I have the TG 35s" on my truck & had to cut a ton of plastic out. Plus, used an angel grinder w/ a cutting disc to trim out about 2" of metal on the left & right of each wheel well. This was front only, the rear tires fit, but very[I[/I] tight.
One of the most important clearance issuses I was confronted with was the wheel backset. The more the better, my wheel backset is 5". I think a four inch backset would be cutting it VERY close. Do not believe 35"s will fit, even with a 6" lift. You will have to hack out the front wheel wells regardless. Also had to unbolt the washerfluid reservoir & push forward a bit.
vsaravia
