running rcas and remote wire
96GMCYukonGT
ive got 96 yukon and was wondering whats the easiest way to run the rcas and remote wire for my amp through the dash? when i changed my head unit i didnt really see anywhere so i thought id ask
groundscr8pr
flaccid member
scarborough maine
i those i go down the pass side. if you remove the glove box you will be able to kind of follow the factory antenna wire then down to the kick panel and back from there.
96GMCYukonGT
96GMCYukonGT
just regular old rca cables not huge or anything just so i have an idea where to run them through the dash
Ryan1126
run them behind the glove box and down the passenger side, then run your power down the drivers side, since i am assuming you are going to be installing an amplifier.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there will be a wire track groove in body under sill plates that will connect to dash by passing underneath the kick panel. Plenty of room.
veteran111
