Power gain help.
Army Cowboy
North Carolina
I am new to all this FI engine stuff, I am use to the older motors where you can stroke, change cam, lifter etc. My wife has a 2007 Tahoe LT1, 4x4, 5.3L and I am looking to put a Volant exhaust and air intake on it. We use her Tahoe to tow our 23 ft wakeboard boat and I am looking for some added power and to try to get some better fuel milage. I am wondering what kind of power gain would I get from those bolt on mods?
Here are the mods I am wanting to do:
http://volantperformance.com/s2/Scripts/prodView.asp?idproduct=213
http://volantperformance.com/s2/Scripts/prodView.asp?idproduct=730
I know I won't get a lot more power over stock untill I get a tune to tap into the added power. I am just looking for a rough number is all.
I also know you cannot get the same power from a gas tune that you can from a diesel tune. I was thinking about getting a Duramax next year but now I might get another Tahoe but not 100% sure.
msj724
Youngstown, OH
I installed a K&N Air intake with an MBRP Performance Exhaust before my tune. The intake was listed with an increase of 17 HP at like 4000 RPM, and the exhaust was around 15-20 HP also at higher RPM. 32-37 horsepower seems like a lot, but you still won't feel much. I do notice when I get into the higher RPM range that my Tahoe has a little more pull, but for all around driving you won't feel much difference. I know you are buying Volant, but I am sure all of these companies set their products to see similar gains so it you should probably see similar numbers.
blueflamed03
Oklahoma
air intake will help some, but ever so slightly. I say a custom tune is in order doing that towing.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Really it all comes down to weight when you are towing a boat. I have a 03 Tahoe LT and i tow my 2007 24ft boston whaler. the boat and trailer weigh almost 8,000 lbs which is way to much. i would say if your towing no more then 5,000 lbs your good. You still have a nice load size with some comfort still left in the ride.
A
Army Cowboy
North Carolina
Its a Yamaha 23ft wakeboard boat and weights about 5,000 lbs with trailer dry. With gear and fuel it weights in around 6,000-6,500 lbs, and according to GM our Tahoe has a 7,300 lbs tow rating. So I am good on the weight there, I just would like a lil more power is all.
Thank you for all your help.
rossida
