OEM Clone Headlight HID/Projector Retrofit Project [video update]
soulsea
soulsea
Bar
So serge, I know you said the quad projectors cost more and the ones with just one projector per side already runs over $1k. How much more is it for quads?
All in around $1500 give or take a buck. :)
THE YETI
Director of Operations
South FL
soulsea
soulsea
Bar
No kidding ... I went over there for attention ******* only to realize that sumo was already a god over there. Massive fail! :(
Actually no, just sharing with other enthusiasts and mentioning TYF in the process.
Kman
Southern California
I like the bright white LED on your DRL/Switchback. I'd be interested in getting some white LED lights like you have if they come in 4114 (none switchback). Is it possible to get them?
soulsea
soulsea
Bar
Mmm, well I got them from v-leds so these are the straight white (no switchback) in 4114: http://www.v-leds.com/catalogsearch/result/?q=4114
Although those have 6 less leds than the ones I have so I'm pretty sure they will be as bright.
Another vendor everyone seems to be happy with is http://autolumination.com/ but I can't see 4114s there.
Kman
Southern California
Thanks guys. On your HyHoe, you running 5k or 6k?
Is it plug and play or would I have to install a resistor or whatever so the LED's don't burn out, or is that only for turn signal lights?
Just noticed this:
WARNING
Not for use in continuous on applications such as DRLs. Bulb failure may occur if on high output mode for more that 15 minutes due to over heating.
soulsea
soulsea
Bar
Keith I run 5k.
I'm not an expert on these but I'm not running load resistors on the drls, I run them only for the blinker elements of the switchbacks. In fact my understanding is that have load resistors on drls is not only not necessary on dual circuit leds (which these are) but in fact could end up overheating.
So the short answer is yes, they are plug and play. :)
Kman
Southern California
Keith I run 5k.
Good to know. I'd love to run these in my DRLs but I'd hate to spend $60 in lights and have them burn-up in 20 minutes.
Think that would happen?
THE YETI
South FL
are the 4114 compatible with 3157? I noticed the disclaimer at the bottom as well.
soulsea
soulsea
Bar
Not sure. The stock 3157 and 4114 bulbs side by side look identical if that's what you're asking.
Keith, best way to know for sure is to call v-leds and just ask them ... my experience with them is one of great customer service which includes willingness to answer compatibility questions.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Haha Serge, im not a god overthere just the 2nd one to do a retro on a nnbs and now theres 3 of us. As far as Drl. I run autolumination 3157 dual circuit bulbs. Dual circuit meaning that if there is a spike in the current, it wont burn out the Bulb, 3157 will take tghe place of the 4114 even using switchbacks
THE YETI
South FL
Speaking of v-LEDs, you, and switchbacks... You must have bought them all because I ordered them a month ago and they are still on backorder!!! Grrrrr!!!
soulsea
soulsea
Bar
They have been notified and will release thy leds when I haz bumper. :waytogo:
Avalanche2007
Hello Serge. Which type of dual color LED you have on your car?
I got your answer in Ian's page :) thank you
soulsea
soulsea
Bar
Quick update ...
It's almost been a month now since I had these installed and I couldn't be happier. They've been trough 110F heat index, pouring rain, hurricane, DC streets, and so far have held up perfectly. Not a single person has flashed their lights at me day or night. We'll see how they hold up over the winter but so far so good.
On a side note ... I've had a 2" rear drop leveling kit sitting in the closet for a few weeks torn as to whether to install it or not for fear of raising the projectors' beam angle and blinding oncoming traffic. I had all but given up on the prospect of putting it on and I was going to sell it, but now I'm thinking I might take a run at it. We were conservative with the beam pattern height so perhaps I have a little room to go up.
So when I have some time next week I will indeed have it installed and see what happens ... worse case scenario my lights will go too high and I'll just take it off and sell it.
Cheers!
