Post your setups!!
billowred
I am running 6" Fabtech Lift 3" BL Keys.Rear is Pro Comp 6 inch Progressive Springs. 38x12.5x16.5 SS TSLs. 4.88 Yukon gears and Yukon Grizzly Locker rear.
Very nice!
'93Yuke
I have a 6" suspension lift, cranked torsion bars, and 3" body lift. running 325/85/16 michelin XML military tires, on 16X10 ultra aluminum mags. about to add 3" keys, and find some way to bring the rear up about 4"
bowtiefreak
bowtiefreak
No Quarter
Near Philly
3" keys? I would advise against that. Try cranking your stockers....and 3" is way too much. if you want that much more lift....buy a bigger lift
'93Yuke
the stock ones are cranked already.. I wanted to use the keys because I want more lift without having to buy a bigger one. as far as i can see the next step up is a 10" whiplash lift.
96ProCompTahoe
IN
you crank those keys any farther and you won't have a 4wd anymore. those front shafts won't last long if they are even long enough to begin with... SAS or buy a better IFS lift. you need to drop the diff not crank the keys.
'93Yuke
My cv axles are maxed about.. it took me almost 4 hours to get the old ones out and put new ones in because of the extreme angle.. I would love to do a SAS but that can get really expensive really fast. If I bought a taller IFS lift would I have to get the extreme CV axles as well? and are there other companies besides whiplash that make such a lift?
NOVAhoe
Manassas, VA
i just cranked my stock torsion bars today, i cranked them all the way up and went down from there till i liked it, its still a little too high in the front i think, ill just get 1.5 inch blocks for the rear now, when i first cranked them i got about 3 inches, now its at about 2 over stock in the front, ill post up again this week when i get my new wheels and tires put on it
'93Yuke
here's a better look at her. note: it has new exhaust now and the GMC symbol, and skid plate are orange now.
SWCHEEZ
new to the forum, first pic of my hoe im posting.
All stock, ranch hand brush guard and tail light guards. Sitting 31' BFG A/T's
setty7
steamroller...what are you cranked to in the front and what do you have in the rear?
steamroller
The South
Rough Country 6" w/their shocks
ORD shackle flip
JKW Offroad tapered zero rate to push the axle back due to the shackle flip and correct pinion angle
^^This plus the AAL (comes with the 6" kit). As far as cranking goes I lost track when I put the Realifts in. Tires clear fine other than in reverse with the wheels at full lock. Stop being so indecisive, order the lift and get to work! :D
sparg93
Expedition Tahoe
NJ
Cell phone photo...I'm also on a hill, so the front looks a bit higher then the rear, but its only about a 1" difference. Also, I did not have to trim (5" bs) and the wheels just squeeze by w/o rubbing.
1.5" Crank
Mickey Thompson Classics - 17x9
ProComp Extreme AT - 285/70R17
briannorris
