Modded
That Guy
- Joined
- May 3, 2009
- Posts
- 6,942
- Reaction score
- 109
Mybad guys I have not gone yet, too lazy haha!
Thanks for the update (though not the answer I was hoping for). I was going to make an appointment to do the TSB next Wed, might not waste my time...just a update on this. Have a older customer called me on this last week and I had a set of 2509 belltech spindles here that I will be putting on his truck this weekend to see if this resolves the problem. He had the dealership do the tsb and it still does it![]()
alot of other makers have issues with the stability control etc kicking in and causing problems once lifted or lowered. on our tundras, most of us have had to do a zero point calibration after going up or the ESP would kick in on the slightest curve.... one option, and not sure how the GM sensor is, that some found was to place washers under the bolt holding the sensor in place to space it up, and angle it back to the angle it was at factory height. its all when changing the rake of the truck- trucks are supposed to sit higher in the back than the front and when people lower or worse (cali lean) and make the back sit lower or exactly even, it causes the sensor to read wrong.....
so far i have not had one belltech spindle do this. Im trying to see why the mcgaughys is causing this.
