wondering if you guys could educate me on the net effect on gear ratio with my wheel & tire change.
I went from 265/70R16 tires to 275/55R20 tires. I have 3:42 gears in the rear, what did the change in tire size do to my gear ratio?
You have 3.42:1 gear, not 3:42. When doing maths you never know if a typo could royally skreu things up. OK
Every piece of advice given so far is true, but there are pieces of info missing.
GM undergeared nearly every vehicle with a V8 in it since the 70s when CAFE MpG testing became a thing, to try to get slightly better CAFE MpG scores.
Tests results are unrealistic, so they don't directly apply to the real world as well as they should.
With GMT800s, anything under 3.73 needs some help off the showroom floor (in my experienced opinion).
Installing 4.10 in place of 3.42 makes many people think they gained a lot of power.
Although the engine itself may not be any stronger or more powerful, going from 3.42 (or even 3.73) to 4.10 has two undeniable measurable effects:
*Tow rating improves - in the Owner's Manual under 'Weight of The Trailer', it turns out that:
a 4.8L with 3.73 is tow rated same as a 5.3L with 3.42 - 6800lb
a 4.8L with 4.10 is tow rated same as a 5.3L with 3.73 - 7600lb
so an argument could definitely be made that gears are worth strength, since Power = Strength / Time
There are of course diminishing returns, no sense trying to tow anything over 2x the weight of a Tahoe, just 'cause it has 4.56 - got Suburbans for that much or more.
*If one were to measure, let's say, 0-some speed, or time to distance like a 1/4 mile or 1/2 mile, even with the same engine making the same power,
it'd be impossible to deny that better gear would result in quicker time to speed and time to distance. Since Power = Strength / Time,
even if both vehicles have the same engine, the quicker one made better use of it by putting more power to the ground thru the tires.
Again, diminishing returns; typically the only Tahoes / Suburbans (1500) with 4.56 or more gear have HUGE tires with aftermarket suspensions to suit,
specifically to make up for the much taller tires - which some people forget are also MUCH HEAVIER, even without heavier wheels.
Taken together:
taller tires have a weakening effect on axle gearing
any additional weight towed / hauled would be benefited by more axle gear
GM already hobbled most GMT800 suvs with barely enough gear as is
Long story short: most Tahoes and Suburbans (1500) would be helped by 4.10 gear.
