cleaning the carpet, need help
drowndindreams
Unknown
I just spent the last hour pulling the seats out. My plan is to clean the living shit out of this carpet as well as I can. I'm guessing using 409 or something like that and just getting a brush, hosing down the carpet and going at it. Anything I should be aware of, or anything I should be using?
Here are two lovely pictures
SunlitComet
OBS Jedi-Do Good
unknown at this time.
not hosing it down would be good. call a commercial carpet professional. Put the carpet on the ground and let them go at it. Maybe even do the home and get a discount. I was set to do the same thing but then I saw it in daylight. Original carpet never made it back in.
fyremanpat
Fyremanpat
if you can, pull it out and hose it off. once its wet try working the stains out. this way you will be able to rinse the dirt away. if you try to wet vac it in the vehicle its only going to draw up the dirt from the padding and it will look worse when it dries. if you do leave it in the truck use water and cleaners sparingly. ive had luck with just a steamer and wiping the carpet with a towel.
drowndindreams
drowndindreams
Unknown
i just hosed it down, brushed the whole thing down with stain remover, hosed it down, brushed it again with washing detergent, hosed it down again. waiting for it to dry to post results.
Monstar_est87
City of Angeles
wat about removing the carpet and taking it 2 a self car wash place and using their high pressure degreaser settings... Boom..!
drowndindreams
drowndindreams
Unknown
well after it being outside for 2 days, here is the result. i paid more attention to where the foot areas. not great, but looks a ton cleaner.
SunlitComet
OBS Jedi-Do Good
Sorry I still have not gotten the camera thing straight out for carpet pictures but here is what I have. I have to vacuum still. Still debris left over from other work to say nothing about recovering the front seats. For now that will have to wait. Maybe later this year. I want to do some more engine mods first and I don't usually have anyone with me in the truck anyhow. Unfortunately at the moment my engine has become instantly very ill when, during at full throttle test run, it started having two misfiring cylinders, knocking under loaded acceleration the day after installing a CAI. It since has not disappeared. I have to attend to that right now.
I think your carpet came out good after all. Look at my old one.
http://www.tahoeyukonforum.com/forum/showthread.php?t=24985&highlight=them+carpets
AdrienR
