Question about installing shock with extenders
derk
Saskatchewan
Hey guys
Im installing my new bilstein shocks i just got and i have a question.
My Tahoe has a ~3/5 drop. This came with the Tahoe when i bought it. It also has shock extenders. My Bilstein shocks are a bit shorter then the other shocks that were in there already. Should i take out the extenders? If i dont i will have to have the Bilstien shock a little more compressed. (in not sure if this better or worse)
attached is some photos to look at.
Thanks for the help
Derk
D
derk
Saskatchewan
Its a bit hard to see in the pic but this is with the old shock in place.
When i jack up my tahoe by the frame and the wheels are off the ground the old shock is fully extended from top bolt to the shock extender with no presure.
So when i install the new shock i will have to put pressure on the axle to lift it up so the bold hole line up with the shock extender hole.
So i just wondering is it better to:
1)Compress the coil spring (axle up) MORE and have the shock go into the shock extender
or
2) Compress the coil spring (axle up) A LITTLE and have the shock go into the oem shock mounts (remove extenders)
I know its better to have less of an angle for the shocks to move up and down but im wondering about haveing to compress the coil spring the extra bit(when axel is full extended.)
Also can anyone tell me if the old shock i had in the pic is the oem shock??
Thanks So much sorry for such a long post.
Derk
D
derk
Saskatchewan
I went a head a installed them with the shock extenders. I dont see why this will effect too much.
One other questions.
One the driver side, where the brake line crosses the shock, Do you run the brake line infront of the shock or behind the shock. I kept it the same as it was, which was behind the shock. It just seems wierd how it rubs on the shock rubber.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
my ebrake is routed the same way. The reason why the shock looked shorter is becuase the axle just needed to be raised to install onto the Shock. Am i right?
D
derk
Saskatchewan
Ya. I tried changing them one at a time but found it is slot easier to do them both at the same time
CKendrick
