Factory BOSE Amp location
2K6TBSS
East Bay, CA
Wondering where it is. I have looked in the rear passenger side of the cargo area and found nothing. That is where is was in my 06 TBSS...
Here is why I need to know, the BOSE amp died and I have an aftermarket amp that I want to install. Was hoping that I could just use the factory BOSE location and factory wires. I know that I 'should" run new wires for the new amp, but I am lazy and don't want to have to take the doors apart if I don't have to.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
There was a power amplifier under the drivers seat if installed. I will assume it was bose. That what my truck had before it was removed I think. My build sheet said an 8-speaker system so I guess that was bose. By the time I got the truck things were changed out and the amp wiring was tucked back in the carpet hole. We are talking 91-99 years correct?
---------- Post added at 12:52 PM ---------- Previous post was at 12:50 PM ----------
Besure to check and see if its relay for the amp itself failed.
2K6TBSS
East Bay, CA
I will look under the driver seat also, but I don't remember seeing anything under there (or at least anything that looked like an amp).
Yes, we are talking about a 99 Denali.
2K6TBSS
East Bay, CA
Looked behind the glovebox, and found nothing. Guess I will be pulling the center console out next.
2K6TBSS
East Bay, CA
Is there a wire diagram floating around somewhere that I can reference? I tried searching, and came up with nothing.
Or anyone that works at a GM dealer, that might have access to wire diagrams?
If not, then I will probably just run new wires.
SunlitComet
OBS Jedi-Do Good
Here: Larger pictures just take more time to publish. I have to download them, upload to another server and publish for web use.
turbocharged01
i"ve been looking all over for these Thanks, Now only if I knew what it meant lol, returns and feeds what happend to inputs and out puts
knoslf
Thornton, CO
Try these:
Nice...do you know the factory speaker colors? The a**hole that owned my 99 Yukon slt CUT the factory plugs and im having major issues installing my cd player, only have one speaker to come on lol....thanks
veteran111
