z120bt in 09 Tahoe LTZ
P
ptwat
Yes thanks that helps a lot.
I placed the new HU in there to test fit without any cutting and was able to screw it down but did not replace the front woodgrain cover since it is hard to remove. It did not appear to me that you get much new room to cut plastic where the stars are because of the metal piece behind the beige and the black plastic. I will look at it again once I get my cabling completed.
Modded
That Guy
All I did was remove the screws in the top plastic area, then cut off the top plastic. I left the bottom one and was still easily able to fit a PAC OS-4, SWI-PS and parking brake relay all with ease!
P
ptwat
When I was looking at that I thought leaving either the top or bottom piece intact would keep things from possibly developing a rattle. It is hard to tell where the HU is hitting first on the top or the bottom but cutting the top only gives the extra depth of two layers of plastic (maybe 3/16"?). Sounds like that may be all that is needed so it must be that fan protrusion on right hand side of the back that is hitting first.
Did you use the metal piece behind the plastic as your ground (since there are already holes and screws) for the bypass and equipment ground?
Modded
That Guy
No, I used an existing metal piece with a screw that was behind the A/C controls. Its pretty much below the head unit, a copper colored piece if I remember right.
P
ptwat
Trying to decide what SWC buttons to program to what function in the SWI-PS. Can you program more than one function (e.g. Track Up/ Seek Up and Preset Up/ Disc UP) or does the second function programmed over-write the first? I'll admit up front I have just now started thinking about this. Not sure which functions are available on the z120bt that are on the SWI-PS (1 thru 13) and are the most convenient (with maybe the exception of Vol UP and Down).
P
ptwat
I am going to add pictures of what I have been doing hopefully to help anyone else that is or will do this change to a aftermarket HU in a Tahoe or similar vehicle. This next picture is the HU well with the first layer of plastic cut out. I used a dremel tool and it took about 20 seconds to cut the back out.
P
ptwat
I decided that cutting the second black layer was not necessary but I did cut out a square where the cooling fan is on the HU to improve airflow at the top right hand side.
P
ptwat
These are the plastic parts I cut out.
P
ptwat
Harness made up. Combined OS-4, Z120BT and GMRVD harnesses with SWI-PS, RAP relay, chime module. OS-4 is not shown (not back from PAC yet).
P
ptwat
Console and HU/dash surround. The cup holder is remove and the woodgrain HU surround is off.
P
ptwat
Underside of cupholder showing tabs that hold the cupholder in. I removed the metal clips since I was going to be removing and replacing cupholder over several days.
P
ptwat
Backside of HU surround showing retaining tab and clip locations.
P
ptwat
Hole in console (looking from above) with USB and video plug from Z120BT. After this picture I added a rubber grommet to the hole to dress it up.
vietcu
Very nice ptwat, good luck with the install. One thing though, you are going to love the "chime" once you turn on your system with that new chime module ;), especially when turning on the turn signals.
Modded
That Guy
Yeah the chime was weird at first but I got used to it quick!
P
ptwat
Thanks, I figured I would put the pictures in as I go so that if someone else was doing this or similar that they could see what it looks like on the inside.
Got a call from PAC yesterday that they were sending my OS-4 back. I guess it will be another 3-4 days before I get up and running.
Did either of you look into a different chime module?
vietcu
it is easy enough to change to another module. but trying to find one is another story, still looking around for another.
Modded
That Guy
Nope, their is not much of an option. And after a month of use you won't even think of it as anything!:Handshake:
P
ptwat
I got my OS4 back yesterday (upgraded to 1.2.3.8b) and started the install last night. With all the cabling I ended up cutting more plastic at the bottom of the HU well. I installed the GMBACKUP connector to the wrong connector and it took a while to realize it (brown to brown- doh) so backup works. I also have CENTER and SUB connected to the Z120BT CENTER and SUB out but I don't know if I can tell the difference if they are connected or not. I also came to the realization that I can either have a/v inputs from the RSE or (OEM) XM radio but not both with the GMRVD cable on A/V-2. I have an IPOD interface on A/V-1. I still need to install the bluetooth mike and a permanent GPS antenna. The PAC support told me the fader does not work since the Tahoe/Bose has only two imputs. Seems like fade worked on the OEM HU but can't recall now.
The GPS connector is very much different on the OEM than what came with the 120bt (as you guys know) I took the blue plastic off the OEM and still could not get a good fit with the HU- so I am still thinking about that one. I thought about taking the end off the Pioneer antenna and putting it on the OEM but then thought I would ask you guys what you did with your installs.
048tahoe
