37" MTRs on a 6" lift?
McAllister513
Not a SUV but it will give you an Idea of how high your need to go. I have a 7inch CST with a 3inch Body Lift and I am running a 315/75/R16. I perosnally wouldnt run any bigger of a tire on my set up. Stuffing is retarded and breaks stuff.
Some Crappy pics off my BlackBerry
I only have a 8 inch lift and my 37s fit perfect with minor trimming of the back of the fender wells!!!
Cartwright
Are you 2wd or 4wd? What tires and do they run true to size? I'm not a fan of trimming personally. If they don't fit without trimming then they are to big :imo:
McAllister513
2WD! And I'm running toyo open country m/t and yes they run true!
I would rathe trim some rather then have a huge truck and small ass tires! Not a fan of the "cen cal" trucks lol
Cartwright
Post up a picture. I see you being hella stuffed. There is a diffrence between CenCal and having some clearence. My truck is Def. not CenCal but I clear my tires perfectly.
Luke01liftedtahoe
I'm lifting it because I like lifted trucks. I have had plenty of off-road rigs (jeeps) so I am a fan of that endeavor also, but not in my tahoe.
As far as lift goes, I am looking at doing a 3" suspension lift with a 3" body lift. From what I have read, the suggested tire size is 315/75r16 or 36x12.50x16.
Can you tell me more about the rubbing-when-turning problem? Are you saying the rubbing isn't in the fenderwell, but actually at the bumper(s)?
6in suspension 3in body is the only way that can be done without the major use of a Sawzall...
outcast99
I’m on 22x12, 2” spacer on my truck running 37” Landspider m/t with my 6” lift and only rub at Lock with a norcal mod…. But I also have a move bumper
scottd
