Tahoe Spraying gas from above gas tank? Please help!
Anthony
2004 Tahoe LT (MA)
Westen MA
UGGHHH, another problem with the Tahoe.
I just replaced a bad fuel injector (#7) 2 weeks ago and replaced all my spark-plugs last week and today I go to get into the Tahoe it seems that it cranks very long before it started, but it did start fine then I went to work and all was fine.
I come home an park and smell gas, i look under car and don't see anything so I am unsure what to do.
Then a hour later I go to the store and when I go to park I smell GAS big time and look under the car and gas is spraying everywhere! it is dripping all under the fuel tank and looks like its coming from the top. I am unsure what to do and drive home (This was prolly unsafe) and park the car and its leaking again (7 gallons between the store and home) and i go under to look closer and it looks like the leak is occurring right where the fuel pump is.
Question: what do I do now? My mom can drive me to work tomorrow and rest of week if I need to go to shop. What is my problem? I figured it was fuel pump and ordered a new one tonight with overnight shipping and it will be here Wednesday.
Do I need a flat bed to get this to a shop? How much will it cost?
I got my fuel pump for $250 shipped, much less then dealer at $450ish
PLEASE HELP AND THANK YOU!
I doubt it'll be fixed by then (for some reason Stealerships seem to take forever, but it's possible if it gets there today)
If the recall isn't the issue, replace that shit yourself and have it done by Friday ;)
UGH, I have a trip planned to Niagara falls for next Monday to thursday with the girlfriend....might need to get cancelled now....sucks
Also my part should be here tomorrow so I am going to call shops and see what they charge as well as calling AAA about getting towed on a flatbed to a shop.
***Called the local Chevy dealer and there is no recall on my Tahoe after giving my VIN number...***
ScottyBoy
Shreveport, La
There was a recall for this issue. Some kind of fuel reservoir thing that was prone to leaking and possibly causing a fire. I had mine replaced right after I bought my truck and got the recall notice. Call the dealer with your vin and see if the recall service has ever been performed on your truck. If not, the dealer should have to fix it for free.
EDIT: And do NOT drive it like that. If the gas gets into any of the hot electricl fuel pump wiring it will go BOOM!!
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
Could you do me a huge favor and find that recall or its item number? I tried look for it and unable to find. Do I just call up any Chevy dealer around here and state the issue I am having and then give them my VIN? I dont know how this works lol
thanks:Handshake:
hassoun
Germantown, MD
let me get that info for you. gimme a minute
---------- Post added at 12:41 AM ---------- Previous post was at 12:40 AM ----------
what year and model is your hoe ?
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
2004 Tahoe LT 5.3 GAS (Not flex lol)
AWD too
hassoun
Germantown, MD
sorry man, cant find anything about that recall. most likely your fuel filter is lose. can you drop the tank on your own and verify that teh fuel filter is tight ? it could be a broken hose or just a loose hose.
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
Thanks, my Year 2004-2006 Tahoe have the fuel filter built into the fuel pump (I think awful idea) and do you think that I should replace the entire fuel pump if I am going through the hassle of getting the tank down in the first place?
So you think this is a simple hose repair and I don't need a fuel pump?
hassoun
Germantown, MD
has your fuel pump ever been changed ? if not then its time for you change it before it leaves you stranded. i changed mine with a NAPA one couple months ago. dropping the tank is easy just make sure u have as few gallons as possible. it couple be a loose hose. but nothing can be determined until u drop the tank. make sure you dont drive it like that anthony!!!
ScottyBoy
Shreveport, La
APR 14, 2005 | Recall ID# 76002 Hide Details
Recall Reason FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMP
Recall Date APR 14, 2005
Model Affected TAHOE
Potential Units Affected 316508
Recall Summary
CERTAIN TRUCKS AND SPORT UTILITY VEHICLES WERE BUILT WITH FUEL MODULE RESERVOIR ASSEMBLIES THAT CONTAIN FUEL PUMP WIRES CONNECTORS MAY OVERHEAT UNDER CERTAIN OPERATING CONDITIONS.
Consequence
IF THE IGNITION CIRCUIT WIRE IS EXPOSED, THE FUEL PUMP FUSE WILL BLOW, DISABLING THE FUEL PUMP AND CAUSING AN ENGINE STALL OR NO-START CONDITION. IF SUFFICIENT HEAT IS CONDUCTED TO THE PASS-THROUGH CONNECTOR, A HOLE IN THE CONNECTOR MAY RESULT, WHICH MAY CAUSE A 'SERVICE ENGINE SOON' LIGHT TO BE ILLUMINATED DURING THE EMISSION SYSTEM DIAGNOSTIC ROUTINE. FUEL VAPOR AND IN SOME CASES LIQUID FUEL MAY LEAK OUT OF THE FUEL TANK THROUGH THE HOLE IN THE CONNECTOR BODY. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE. ALSO IF THE IGNITION CIRCUIT OR GROUND WIRE IS EXPOSED AND SHORTS TO THE FUEL LEVEL SENDER CARD WIRES, INACCURATE FUEL LEVEL READINGS MAY RESULT.
Remedy
DEALERS WILL REMOVE THE FUEL TANK, AND REMOVE THE MODULE RESERVOIR ASSEMBLIES FROM THE TANK, AND INSTALL A NEW SERVICE KIT FREE OF CHARGE. AN INTERIM LETTER TO OWNERS WAS MAILED ON MAY 25, 2005. THE OWNERS WERE RE-NOTIFIED ON OCTOBER 19, 2005, SINCE PARTS ARE NOW AVAILABE. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438 AND GMC AT 1-866-996-9463.
---------- Post added at 01:20 AM ---------- Previous post was at 01:17 AM ----------
MAY 19, 2006 | Recall ID# 53790 Hide Details
Recall Date MAY 19, 2006
Potential Units Affected 88303
Recall Summary
CERTAIN REPLACEMENT FUEL FILTERS, FRAM BRAND NAME P/N G3727, WITH DATE CODES X52911 THROUGH X60801 SEQUENTIALLY OR X600141 AND A MEXICO COUNTRY OR ORIGIN MARKING ON THE FUEL FILTER HOUSING MANUFACTURED FROM OCTOBER 18, 2005, THROUGH MARCH 21, 2006, SOLD FOR USE ON THE VEHICLES LISTED ABOVE AND ON CERTAIN SCHOOL BUSES. (TO SEE THE SCHOOL BUS ENGINE SIZES, CLICK ON "DOCUMENT SEARCH" AND THEN "BUS APPLICATIONS"). THE CONNECTOR ON THE FUEL FILTER WAS NOT MANUFACTURED TO HONEYWELL'S SPECIFICATION. AS A RESULT, THE O-RING MAY NOT SEAT CORRECTLY ON THE FUEL LINE.
Consequence
THIS CONDITION MAY CAUSE AN INADEQUATE SEAL AT THE CONNECTION, POTENTIALLY LEADING TO A FUEL LEAK. IN THE PRESENCE OF AN IGNITION SOURCE, A FIRE COULD OCCUR.
Remedy
HONEYWELL WILL NOTIFY OWNERS AND REPLACE THE FUEL FILTERS FREE OF CHARGE. THE RECALL BEGAN ON OCTOBER 18, 2006. OWNERS MAY CONTACT FRAM CUSTOMER SERVICE AT 1-800-890-2075 (OPTION 1).
Notes
HONEYWELL INTERNATIONAL, INC.
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
Recall Summary
Consequence
Remedy
Recall Summary
Consequence
Remedy
Notes
So, how do I go about seeing if this is my issue? DO I call the 1-800 number or do I call the dealership?
ecordell
CordellDesigns.com
Merica
Dude, call the Chevy Dealership, give them your VIN and they can look it up and see if this issue pertains to your Tahoe.
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
Thanks, will do. I don't have a fuel filter (It's in the fuel pump) so I hope this applies to me and I really need to get my Hoe fixed by Friday
ecordell
CordellDesigns.com
Merica
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
Update,
Called some shops in town and 1 founded very familiar with the issue. He said that stuff gets caught on top of tank where the fuel pump rests and rots out and causes the sender unit to rot and causes a leak when the system pressurizes. HE also said he couldn't give quote over phone until he saw it. He said Thursday morning he can take it in too. I'll keep this thread updated and anyone please put down some input if you have it!
Any idea what I'm looking at to pay for this? I already have the new fuel pump and using tools online it estimated that the repair is between $200-650 in labor. All dependent on where you go.
Hodmjstone
