Replacement headlight lens?
OneofFew
Talullah Falls, Ga
All the aftermarket headlights seem to be mediocre and assemblies flimsy to where the headlight wiggles around when going over bumps.
I was thinking surely there has to be someone that has made just the lens so we can simply replace that. If we could just replace the lens itself, it should be a whole lot cheaper and we would not have to put up with the cheaply made assemblies.
Any leads?
S33k3r
Dallas, Texas
Maybe take a look at the frames behind them. Make sure yours isn't loose. But, also, you might fasten things down more there. I haven't had these issues. I just get water in mine... :(
When i bought aftermarket headlights I swapped over the plastic brackets from the OEM lights to the new lights, as they came with cheap, flimsy assemblies. It's like having the original lights. They don't move or wiggle at all. Rock steady.
mountie
I just started to consider replacing my headlight housings for my ’05 Yukon. >> I have polished them a few times and …they don’t look too bad, considering,…. I’d like some clearer lenses again. OEM style. Searching for GOOD HOUSINGS is all over the place online.
OK….. Where do I get the BEST replacement housings???? …. and why so cheap? ( under $60.00 ? )
mikez71
My TYC housings look ok, and haven't gotten water in them yet.. (only gone through a carwash so far)
They have a bulb shroud, which I feel probably reduces light spread.. (light output/pattern not great)
Also the bulb sockets have almost no tension in the housing.
I don't notice any bouncing (could be because it's such a weak beam), but the adjusters don't feel great either..
I'm considering trying the Depo crystal lens..
I don't like the projector look, and I heard the projector bracket is different from stock.
(In case I want to retrofit OEM brackets like @Tonyrodz suggested)
Not sure if all DEPO or just the projector have different brackets..
mountie
So, the censuses is….. Avoid replacing them, unless one is broken. ( Brightness is OK….. I have the “4-high” chip )
I don't have an answer for you. I don't even remember what brand I bought. Whatever lights you decide on make sure you read the reviews 1st before buying them. Read as many reviews as you can.
The new lenses I bought were really nice. Before putting them on I applied clear with UV protection. They stayed clear for about 6-7 years. I'm thinking about doing it again. They're looking dirty now.
mountie
what ‘clear & UV protection” ?
strutaeng
Dallas, Texas
I did a sand and automotive 2k clearcoat (Kapci brand is what my local auto paint supplier carries, among other brands) to the 3 GMT800s I own, almost 2 years ago. The headlights for sure came out looking like new, the markers looked fair because they get some gunk behind the lens I couldn't really get clean.
Did the taillights as well. Also tuned out nice.:)
X-ray Nerd
