2006 Yukon Denali E fans not working
Slow yukon
Have a 2006 gmc Yukon Denali with. E fans. So I had the engine rebuilt. But when I got it back only the passenger side E fan works and only in high. Fans were working fine before the rebuild. I checked all relays and fuses already. If I take the passenger side connector and put it on the driver side fan the problem follows so I know the fan works?
Any help is appreciated
TJ Baker
Colorado
Have you tried swapping BOTH fan connectors?
ScottyBoy
Shreveport, La
Coolant temp sensor is possibly bad, or simply unplugged. I remember reading about this same exact issue once before and several folks commented that the ECM has a failsafe to run a fan on high when the coolant temp sensor is defective or giving erratic readings.
JasonW4141
