2013 Tahoe soft pedal only after bleeding
Wingeier
Hello all. I have a 2013 Tahoe with 140,000 miles. I recently replaced the front passenger side caliper due to it sticking after a hard brake recently. After replacement, I did the conventional bleed (pump pedal, hold, open bleeder, repeat)
I was unable to get a pedal after several times doing this. I bought a bidirectional scan tool and am able to get what seems most the pedal back. What has me stumped is after I do the ABS bleed, I have a decent pedal. Then I follow it up with the conventional bleed and lose all my pedal. I can regain my pedal just by running the abs bleed after all of this without even opening up the bleeders and just activating the ABS.
Has anyone experienced this or have any advice?
solli5pack
Yes we have. A pressure bleeder is the best way to get all the air out.
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
W
Wingeier
Thank you
Here is a picture
W
Wingeier
This is odd, but maybe it will help someone. I was able to get my pedal back after running the ABS bleed with a scanner. I didn’t open up the bleeders as the prompts on the scanner said to. When I did follow the instructions by opening up the bleeder I always lost my pedal. For some odd reason not opening up the bleeders and letting the ABS cycle all 4 wheels with the scan tool allowed my pedal to be normal. Anyone have theory to why?
jkhuntzinger
