OR VietVet Is Still Throwing $$$ at 2005 Z71
Last but not least. Choice of positive cable attachment. Inside/under the battery box or at the jumper connection?
I would connect the positive cable from the second battery to the same place where the positive cable from the first battery is attached. (In my case, it was the main fusible link on the passenger side firewall.).
GMT800 2005 Tahoe Z71
Navy Supporting Member
The second battery install is all done. The disconnects are right at the second battery. The battery is the 2 year O'Reilly's Super Start and used 5 foot of positive and negative 6 AWG cable and tied off. The positive cable is attached at the Jump Start snap shut positive cable box and the negative is attached with another ground cable at an engine bracket. Tied off at the firewall and protected with 5' convoluted tubing for each cable.
Only concern I have, is not what some of you are thinking about the 6 gauge wire. It is fine for the charging and will keep the battery up to s*n*u*f*f for running off of if needed.
To disconnect, have to loosen the green knobs. When I do that, the knobs will vibrate loose and fall out, over time. If I remove knobs completely, the disconnect mating can fall apart. Need a way to loosen and disconnect and not fall out. Or, take completely out and keep them disconnected without squeezing tight enough to reconnect. Thoughts?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
When I used those type of disconnects before the knobs always stopped like the threads or stud on the back side were staked or mushroomed.
That was what I expected, too. But both unthread easily. I may just rig something like what you talked about.
They tighten easily and loosen easily. I will look tomorrow the see if has enough thread on backside to booger the threads.
Thanks for input.
This morning, I looked at the backside and there was no threads poking thru, when tightened down. I read reviews and found similar complaints and complaints of power not disconnecting. I also tried removing knobs completely and used my battery pliers and pinched the last 2 threads at 4 spots around the ends. That did create a slight drag, that would have kept the knob from rattling out if loosened and driven but did not explains the power non-disconnect. I found a slightly different design, American Made set, that were twice the price. I ordered and are supposed to be here tomorrow afternoon. I will install and post pics.
Did I miss why you didn't go with a relay type setup? You could have a remote switch for off and on.
This is how I would approach it. A heavy duty relay rated for high continuous amperage, with a dash switch for the control circuit. Shades of the old Ford starter solenoids/relays, but more capacity. "Smart" relays and battery isolators are available but I think that complicates what should be a simple system. For me, anyway.
I just decided to do it this simple way, for ease of install and second battery availability. I am not running anything extra on the system. This is just me carrying around a second charged battery. Total cost of this parts setup is about the same as the battery that was brought to me, service call and c/c 3% charge.
Today was oil & filter change day on the Tahoe. I used Valvoline Restore & Protect 5w-30 and a Wix 51522XP deeper filter. Removed filter and changed and all looked good there. I also removed my magnetized oil drain plug and found an absolutely completely clean magnet. Notta/zilch on that magnet. Then I put the 6 quarts of oil in and drove around block. let sit for 15 minutes and rechecked. Was a 1/2 quart low. I added the 1/2 quart and drove again and then waited the same 15 minutes and rechecked and was full. 6.5 quarts? Hmmmmmmm? Then I remembered that I am using a deeper filter. DUH! All good.
No pics because there was nothing to show. All dry under the engine and the transmission and the transfer case. Both diffs dry and all wheel/axle seals dry.
Air filter great, coolant full and clean. Brake and power steering fluid clean and full.
All in all a great BORING oil and filter change.
strutaeng
Dallas, Texas
Nice! BORING oil changes are the best!
I was contemplating ordering those filters, but placed an order of a dozen of the standard ones. Do the long ones hang below the oil pan? The biggest gripe with the standard ones is they sit within the oil pan recess, so my Channelock oil filter pliers can't grip the entire oil filter diameter. Not sure if that makes sense?
If the oil filter would hang lower, I think it would be easier to "spin off," for lack of a better word?
Yes, the Wix 51522XP or even the Wix 51522 is longer than the Wix 51042 standard filter. Longer by approximately 1.5 inches. Same diameter. It is way easier to get an oil filter tool on and still is protected by the surrounded skid plate.
I almost forgot. I always replace the oil drain plug. The rubber seal is always flattened under the old oil drain plug head. You can reuse but I like the new seal. I get the Dorman 090-936CD and that has a 15mm 6 point head on it. There are other Dorman drain plugs with different heads on them and no magnet. I go with what I know works.
strutaeng
Dallas, Texas
Great, Thanks!
jkhuntzinger
