Climate Control Module No Power
kaiokenkai
I have a 2003 z71 Tahoe and my climate control module stopped working (but backlights work as shown in picture). Replaced module ( and tested with 2 other working modules ) no fix , checked fuses, and also replaced blower motor resistor. Anyone else run into this issue or have ANY clue on what this could be ? Any information will be appreciated.
p.s the picture is from another guy i found that had the same problem, but was a dead end thread. same exact issue though.
The backlighting is a separate circuit.
Which fuses have you checked? Do you have voltage to the HVAC controller connector, and ground, at the plug on the back?
Interior fusebox on the driver's side by the door:
Underhood fusebox (in addition to the fuse indicated, check the "RR HVAC" fuse that's next to the Starter relay, just to rule it out):
Sanchize6
What was the solution to your problem?
bluekenworth
We have no idea; the OP hasn't been on here in over a year.
If you have a similar issue, you could provide some vehicle and symptom specifics for the members to ponder.
2003 gmc yukon denali, very new to me, was doing some work and had the battery go dead, auto climate control module was working just fine before and now everything functions normally except the backlights and the screen dont work.
i tried a unit from the salvage yard (not sure it actually works) and same issue, ive checked all the fuses including the tbc fuses, I have 12volt coming into module and good ground, the only thing i can find is the 5 volt refrence wire on the blue plug is reading 10+ volts,
hoping somone might have the wiring diagram to trace the line and see if there is a short, but seems weird that all the controls would work. i dont know much about the 5 volt refrence system but thoughtit would cause more issues with setting temp or changing actuators
also if anyone knows if any pins are specifically responsible for back lights and screen power besides B7 (battery positive voltage), like what voltage i should be getting on a7 (instrument panel lamps dimming control)
So, the automatic HVAC with the digital display.
Does the backlighting work on the instrument panel cluster and on the auxiliary HVAC controls on the overhead console?
Is the instrument panel dimmer pot on the dash control turned up to the detent?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
why is it always the simple things, my dimmer was as low as it could go, I had just assumed it would always keep the screen on a little.
Thank you very much saved me a lot of headaces lol,
Any pics of that blue Kenworth?
bluekenworth
Any pics of that blue Kenworth the blue kenworth was my dream truck as kid never had one, now that im on the road found somthing better
the blue kenworth was the truck I though i would buy when I was old enough for my class 1 (cdl, but now i have my 2002 pete 379 pre emissions with the cat c15 engine, tuned/chipped with few mods dyno 750 to the wheels. will never sell this girl
89Suburban
SE PA
What do you haul? How many miles on her? Looks sweet. That would make a good vehicle mode for Motormaster in Transformers.
bluekenworth
we are a farm so all we haul in superB grain trailers is crops to and from bins and into the elevator, The guy who owned it before me used it to haul fresh produce from the coast of BC into the mainland. truck has 1.6 million miles with an inframe done 300K ago
89Suburban
SE PA
This is our '06 pre-em 379 CAT 18 SP has 1.2MIL same thing in frame 200K ago. They don't make the old style headlights anymore so we had to get a newer hood put on it. I hate the new **** ass headlights. Whelen light bar with ditch lights.
Bentley95
