SpareParts
North Idaho
Yesterday i got the rear evaporator changed. Not to bad a job really. You don't need to remove the entire unit
It is in two pieces held together with clips. Underneath there is just 1 stud you need to remove a nut from. Took about two hours start to finish. Added about 1/2oz of PAG oil also.
After vacuum test filled it with the required 48oz of r134A
Idling in the driveway, temp was 39.4f with front and rear on high and outside temp was 83F
Hoping i fixed the leak.
Bigmike750
You're welcome, Joseph.
Nick,
I hope alll is good, i can’t direct message you yet so forgive me for intruding but I have been having some slipping issues with the 2017 PPV Tahoe, and some hard shifts looking to see what you think I need to do. I would like to have it done close to home, so I wouldn’t have to drive it down to Tucson. Any help would be greatly appreciated.
NickTransmissions
Sin City
The transmission bench
Nick,
Likewise, hope all is well with you also. My PMs are turned off so that folks don't ask me tech questions in PM as it is duplicative for me and defeats the purpose of having an open forum in the first place.
Can't really suggest anything until I have more details such as mileage on the transmission, length of time the symptoms have been going on, any specifics about them (i.e. they only occur when cold or when hot, etc) along with what diagnostics and/or trouble shooting you may have already done along with the results of the diag/TS efforts.
Let me know on the above and we can go from there.
Bigmike750
So it's been doing it for about two years, the car has 167k on the clock(it is a PPV) when I'm on the high at a steady speed, its goodin town it slips in and out not all the time but from time to time it also does it hot and cold if I remember correctly. No trouble shooting at all me and transmissions have a bad relationship
Add @NickTransmissions to each reply to him, so that he knows to that you replied and to look at it. Otherwise, he does not know that you replied to his question, and he won't be searching for it on his own.
NickTransmissions
Sin City
My guess is your pump's pressure regulator valve is beginning to wear; the TC is also likely on borrowed time. I would start planning for a rebuild sometime w/in the next few thousand miles or so as symptoms worsen.
Scrappycrow
Air Force
Alpharetta, Georgia
This morning, I discovered I wasn't just imagining that I was perceiving a binding after coming to a complete stop and then starting off in 1st gear.
I was researching a different subject and ran across a recent post in the "6L80E TRANSMISSION PROBLEMS, CAUSES & FIXES" Facebook group where someone had asked about this. I wasn't surprised to see @NickTransmissions had replied, and that it was likely a leak from the clutch for 1st into the 3/5/R clutch. Oh, goodie. :confused:
Now I'm gonna see if I can use HP Tuners to make it start in 2nd for the time being. Apparently, there's a "snow mode" for other vehicles with the 6L80E that does just that.
Sir_Hiro
Automotive Mad Scientist
Mini Heart Attack. Went to remote start and CEL was on so it didnt turn on. NBD It happens cuz of Exhaust leak.
But after starting it normally the AC wasnt working even though the snowflake was on and no error codes.
Got home and started yukon normally and AC was working. I love GM...
I got my truck back, and the transmission no longer clunks at all, when downshifting. The drum interface for the 3-5-reverse drum and the 4-5-6 drum were installed incorrectly, thus making 2 clutches interfere with each other, rather than operating in sequence. There were also 3 leaky valves. My builder said that this was the most sloppy transmission rebuild that he's seen in a long time (Thank you, GM). He said that the TCM was not even cleaned before re-installing it into the transmission housing. He also installed all known improvement/upgrades to this transmission, along with a billet torque converter.
I'll drive it for a few hundred miles letting the TCM self-adjust and then see where I stand.
the tcm should relearn within 50 miles
homesick
The Best Me I Can Be
Navy Air Force
just ordered this bumper kit from move and lightbars. spent almost 1500, just under 900 for the bumper and the rest on light bars. think people will get out my way on Houston's highways at night? lol
LOL, I don't remember Houston drivers being that smart.
In the late '70s, about 3 snowflakes fell on Houston. The people on the loop that day couldn't run into each other fast enough.
joe
Had to swap in a new starter in Deathscalade last night. For those that do starters on these GMT900's, it's easier to fish it out through the wheel well. Gives you easier access to disconnect the connections and pull the starter out.
solli5pack
Can anyone verify where the rear door drains are? I heard water in the door and pulled a little rubber plug but it looked more like a bumper than a drain. Also any particular reason it would start filling up outta nowhere. We got some intense rain in N.J. so might have been a one off thing. Hopefully.
PG01
Up here to the right
Under that rubber flap
Scrappycrow
Air Force
Alpharetta, Georgia
That's not "more like a bumper," it is a bumper. The reason is a slow buildup until some gunk finally breaks off and clogs up the small drains that are formed by notches in the inner door skin where it meets the folded-over outer door skin. There's at least two, one along the bottom front and one at the rear; the latter of which can be seen by pulling out on the lower seal a bit (not so hard you detach it). i use a cable tie to poke in and around, don't use anything that'd scratch the paint.
solli5pack
Got it. Thanks! Is it normal for water to enter the doors and out the drains?
teamjnz
