Issue Replacing Water Pump
ChrisW
ChrisW
If I didn't thank you previously, in a reply....
THANKS EVERYONE!!
I will update ya'll tomorrow
West 1
Put that down as a nice win. Better to be careful as you were than go in and break a few things. Nice work.
Thanks Again Everyone.
Cleaned the bolts with a wire brush on a Dremel
Blew the holes out,
Put anti-seize on each bolt and screwed them all in without the water pump.
Installed the water pump.
NO leaks
We are good!
Good work. Always clean bolt threads, and clean threaded bolt holes with a thread chaser making these replacements.
2006Tahoe2WD
Silicon Valley
Something odd is going on. You can use a regular tap of the correct thread size and try twisting in by fingers only. The tap should go in rather easily. Maybe get a camera in there and send some pictures back. I'm not sure maybe the later gen. engine has a different water pump design. Have you mixed up a different group of bolts? I put my water pump bolts in with anti-seize because I'm probably going to be the next guy in there.
ChrisW
ChrisW
Already got it back on, see previous post on page 1.
No mix-up in bolts, only bolts off where the water pump and tensioner pulley bolts are, all shown in the photo on page 1.
Thanks for the reply !
Botleader
