Just measured at the outer diameter of the belt grooves and it is 57mm and the spots on the tensioner are also matched for before and after. The front of the two pulleys look a little different.The alt pulleys look a bit different, but maybe that's just the larger edge lip on the new one or the way it was machined. You didn't happen to measure the pulley diameters to compare, did you? Just curious about it.
