03GMCYukonXL
- Joined
- Mar 19, 2023
- Posts
- 147
- Reaction score
- 112
Ok guys, I know this topic has been discussed to death. But...hear me out because I'm not sure what to do here. So, my gauge cluster doesn't want to start when it's hot outside. Just the check engine light. Not movement of the needles or the DIC and PRND. After a few minutes of driving, it will USUALLY come on and start working. Here lately, it wont come on even after 10 minutes or so. So, I build a little test bench and took apart the cluster. Plugged it in, and everything works perfectly lol. I've bent the board (gently), poked all the little resistors, and wiggled everything I could get my fingers on. I can't replicate the issue. I've even actually lifted up one of the 240 resistors near the speedometer stepper motor with my knife, and it came up (need to be resoldered) and it affected nothing. Where do I go from here? Should I just resolder every single joint that I see?
I'm seeing people poke resistor with a pencil eraser to find where their issue is but I can't replicate it that way. Everything seems to work perfectly.
