2003 z71 tahoe
ncalvo
ncalvo
FL
Here's some pics.
Very helpful tip to anyone, you need to make room to drop the front carrier but you do not need to remove the steering link like some people say.
I turned the wheel all the way to lock on the left side and wrestled it for a while, then after I disconnected the idler arm bracket to the frame and that gave me just enough room to drop it down easily
Put in the new reman front diff carrier, did the oil pan gasket, oil level sensor, billet cooler blockoff plate, pickup tube o ring, i went to install aftermarket pickup tube brace but my pickup tube had a support piece already manufactured into it so it wouldnt fit, i buttoned it back up as is.
put the truck up on jacks and sadly my 4wd still does not spin the front wheels, F me lol.
In 4wd on jacks while in park i can rotate the front drive shaft by hand and it spins the front wheels, but in drive with idle speed spinning rear tires only.
so now I just threw big parts at this truck and it most likely is the tcase encoder motor i am thinking. I cannot get the 4wd control panel to put the transfer case in the neutral position either which i am thinking thats a clue the encoder motor failed or too weak.
I had my tcase rebuilt a few years back.
I have NP8 RPO code now i am trying to locate an encoder motor... I think I am going with WAI GLOBAL TC1001 as I can't seem to find a Gm/Acdelco part
Fun fun fun
Usually it's just the range position sensor that goes bad inside the encoder motor. If you have time and a little effort, there are several YouTube videos on replacing them. Or buy a new encoder motor, and fix the old one, for a spare.
ncalvo
ncalvo
FL
hopefully next week i got some time to crawl under there and replace the position sensor in the tcase encoder motor, if that doesn't work i'll replace the entire encoder motor, and i am really hoping that does it. I also might replace output shaft seals on the tcase as I see some drips forming.
after all that work I am really considering doing atomic fab coilovers and hellwig swaybars
ncalvo
ncalvo
FL
Coilovers. no. Hellwig bars, YES.
main reason i am considering them is my driver side torsion bar is cranked and suspension sagging on that side. my truck is perfectly level but the difference in torsion bars has the driver side riding on the bump stop. my truck is leveled on keys, was possibly considering dropping the truck down 1" all around
The front jounce stops should contact the lower control arms at ride height. It's not technically a bump stop, it's a fulcrum point for the front suspension.
ncalvo
ncalvo
FL
Replaced the tcase encoder motor and i have 4wd again
Never threw a CEL or service 4wd message, it was sending power to front drive shaft intermittently and it would not shift into neutral position. New encoder motor solved it20260627_085435.jpg
Drewphil
