Kind of strange thing happened. 95 Yukon backfire and lost power.
Wyo yukon
We took our new to us, 95 GMC Yukon SLE 4x4 on some forest service roads today. Ran perfect until we turn off a main dirt road to a FS road. It back fired, lost power, no throttle response. then slowly regained everything. Not 1-2 min later it did it again this time she died completely. Only to start right backup we continued up the trail for a bit more than turned around. It ran great all the way home.
it had over 3/4 of a tank for gas. running about 40 # oil press, about 180 degrees, voltage was good. The trail she backfired on was at an incline but nothing that was steeper than we hadn't hit earlier in the day. It is the factory TBI 350 with 249K on her.
I am puzzled on what could be wrong/what caused the backfire. Lost of fuel to the TBI?
Thanks
Tim
exp500
How is idle speed? A little hi maybe? Checked for vac leaks?
Where is ignition timing set?#
strutaeng
Dallas, Texas
"I am puzzled on what could be wrong/what caused the backfire." Well, without any additional testing or diagnostics, so are we. LOL
The TBI are known to have common pick-up coil failures.
My brother once showed at my house pulling his 90 RCSB C1500 saying he needed help pulling his bed because the fuel pump was bad. So we pull the bed, and I ask him how he'd determined it was the fuel pump. He shrugged and basically just blamed it because the truck wouldn't start. SMH
After about 15 minutes spent with a test light and spark tester and a bit of Google (I'm not familiar with the TBI but I'm pretty decent diagnosing electricals), I found the pick-up coil was bad. He looked it up and the part itself was almost as much as a complete distributor that came with a new pick-up coil. So he went to buy one, swapped it and the truck fired up. Not saying that's your problem. Test for spark, then go from there.
Pop your distributor cap and check for crusties, especially of you live in the rustbelt or humid regions.
Conedaddy
