2005 Tahoe PCV Hose Routing
Alberta Tahoe
The Tahoe (2005 LM7) is giving that telltale sign of a plugged PCV system with a large cloud of blue smoke on startup. It's also leaking oil which is a condition that's getting worse.
Research points to the above condition.
I'm not necessarily asking for the repair procedure as I'm just going to pull the valve covers, starting with the drivers side and give everything in the PCV train a thorough cleaning.
That brings me to my question.
What exactly is the PCV hose routing? I ask because the web is full of conflicting information and much of that is tied to these engines being installed in vehicles other than what they were originally and the hose routing is modified to remedy the problem that plagues them. That would be in addition to the new and improved valve cover that GM specs in a TSB.
I've got:
PCV valve/fixed orifice hose from the L.S. valve cover to the intake plenum.
A hose to to the throttle body from the R.S. valve cover.
Is there a 3rd hose? Our hot rod LS3 has a hose from the valley pan to the intake tube but no such thing exists on this stock LM& (5.3)
There is more a curiosity adventure more than anything but this inquiring mind wants to know.
Thanks in advance.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I've got:
Thanks in advance.
You will never get the PCV system cleaned out on the D/S valve cover. You will clean it some but it will not last. When I see the clogged LS pcv systems signs, the smoke and the oil leaks, I am putting on a new valve cover, at least the D/S but always do both. Then fix the oil leaks.
A
Alberta Tahoe
Fair comment and I have no illusions as to what I'm contemplating will solve the problem. It's more along the lines will it alleviate the problem and then I have a direction on where to go. A cause and effect sort of thing.
It used to be, before any of these buggies existed (this generation of LM7 that is) that oil smoke on starting pointed to valve guides and oil smoke under full load indicated piston rings.
That said, is the PCV on these engines limited to the two lines? D.S. cover to intake and P.S. cover to throttle body or is there something more?
I'd like to address them all in the simplest way possible and then go from there.
A
Alberta Tahoe
Other posts have popped up since I answered the first.
Especially the oil smoke on start up. Seems the clogged PCV will result in oil pooling in the intake plenum. Then it's ingested when next started.
To the poster that mentioned valve guides...yes sir. That was my initial thought. Then this whole PCV issue came to light.
Thus, my approach to picking the low hanging fruit, so to speak.
A
Alberta Tahoe
Yes. 706 heads.
Interestingly that may be the problem with one of the other Tahoe's in the "fleet".
The 03 has two weak cylinders. 5 and 7 with one at about 70 psi cranking pressure and the other around 130. Doesn't appear to be a head gasket and the suspicion is a couple of burnt valves.
Not that it matters as that truck is due to be parted out and the carcass hauled off to the recycler.
A
Alberta Tahoe
Now, back to the thread title.
Is there a valley pan hose in these engines? Which would be a 3rd hose. I don't see it.
FTR, the crate engine LS3 we have does have one.
mikez71
I don't see a third hose in diagrams. Does the crate ls3 have a connection to both valve covers as well?
I wonder if that engine with low compression on 5&7, could have a gasket leak between cylinders? Not sure if that could cause burnt valves, since there is a fairly large difference in compression still..
A
Alberta Tahoe
I'll have to check the LS3.
It's been hot rodded and is in a 69 C10 so the original layout is just a memory. There may be something in the picture history though.
As for the head gasket, that was an initial thought although, as stated, the difference in compression kind of points otherwise.
If I can manage it (but doubtful) I'd like to pull that engine and do a refresh/rebuild. Then I'll know. It would make for a handy spare or easily sold.
No. Just knock sensor pits.
