Yea, MOOG is not what it used to be.My Moog failed right after the 1 year warranty but my mechanic warrantied it anyways.
Bushings failed enough to see the movement (without trying) when brakes were applied in the driveway.
There are two different grades of Moog, one made in China and one US made. The part numbers are different and the US made has a lifetime warranty. I installed CK80669 and CK80670 (upper and lower numbers) and recommend them. I highly recommend you have AC Delco front alignment kits (45K5012) on hand so you can replace the bolts and camber plates. My bolts were rusted to the upper arm bushings and I had to cut them out with a Sawzall.
www.suspension.com
