bowtiegurl
About 6 months ago my 2007 Yukon service stabilitrak lit up and I was accelerating but not going anywhere. I shut the engine off sat for a few minutes then it started right up and ran like a champ. This happened 2-3 times over the next 6 months. I did put the OBD ll on it one of the times and it had code 2135 but went away. Last week I took electric tape and started taping the wire harness where there was nothing on it. The next day it went into limp mode with code p2135. I unhooked the negative cable for 10 minutes then it started and ran good. No CEL. When I drove it a couple of days later it kept going into REP with the p2135 code. I had to leave the OBD ll connected to keep clearing the code for it to go. The next day I drove it it did it again but this time had codes p1516 and p2135. I can't afford to start throwing money into it blindly. Do you think it could be a wire since it started doing it constantly after putting the electric tape around the wire harness? I have read so many stories of people replacing the throttle body, the TAC and the throttle pedal just for it to be a ground issue or wire broke in the pigtail of the tps connector. Please start me in the right direction. Thank you in advance.
